587,735 active members*
2,834 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Standard linear motion conversion to linear rails.
Results 1 to 12 of 12
    I've converted from the CNC Router Parts standard linear motion to linear rails and bearing blocks.
    I had a friend mill up two 1" aluminum interface plates that I used to attach the linear bearing blocks to the gantry uprights.
    Attachment 395642
    Attachment 395644
    Attachment 395646
    Once the bearing blocks were mounted to the interface plates and the linear rails were installed, I worked on one side at a time. I removed the bolts holding the gantry upright to the CNC Router Parts linear bearing carriages and then removing the cold rolled steel.
    Installed the new linear rail, slide the interface plate on and bolted it to the gantry upright.
    Attachment 395648
    I was also able to move the gear rack up to the top slot on the 80/20 1530 extrusion.
    Attachment 395650
    Two things I neglected to consider...
    •The rail stops were too short and had to be redesigned.
    •The tensioning bracket wasn't supported. I ended up fabbing a new mount from angle iron.
    Attachment 395652
    Attachment 395654
    Attachment 395656
    One benefit of doing this conversion is that I gained an additional 1 1/4" under the gantry.
    I used BLH25F bearing blocks and BLH25Rxxxx linear rail from Automation Overstock.
    Happy to answer any questions!
    Oct 2014
    41
    Re: Standard linear motion conversion to linear rails.
    did you convert both the x & y axis? how's it done on the Y axis? thanks
    I haven't done the Y axis yet.
    The standard CNC Router Parts setup has 2 - 2 1/2" pieces of cold rolled steel, top and bottom. I used one piece of 7" to increase rigidity and haven't quite figured out how to switch over to linear rails and still keep the 7" plate.
    Mar 2011
    357
    What issues did you have with the standard set up that made you want to do this?
    Quote Originally Posted by tkms002 View Post
    I wasn't having any issues, it seemed to be working fine.
    That said, I've seen improvements in the quality of cut since the switch.
    Feb 2005
    829
    I am hoping to see some cut quality improvements, and rigidity improvements.
    Feb 2005
    829
    Quote Originally Posted by bobmagnuson View Post
    Leave the 7inch plate in place and add the linear rail on top of it.
    Mar 2011
    357
    Quote Originally Posted by nlancaster View Post
    What causes a lack of rigidity using the CNCRP skate bearing set up? If the bearings are properly tightened, where is the issue?
    Newbe here. Just trying to figure this out.
    When skate bearings are used like that, the outer race can flex. Linear bearings can carry thousands of pounds without deforming, which would destroy skate bearings
    Then there's the issue with flatness and consistency of thickness. The tighter they are, the more susceptible they are to binding due to thickness variation or unevenness.
    Feb 2005
    829
    Yeah, you can only tighten the skate bearings just so much.
    Feb 2017
    How much for a set of plates? I’m building a new machine based off the standard plans.
    Feb 2012
    19
    Attachment 395642
    Attachment 395644
    Attachment 395646
    Attachment 395648
    Attachment 395650
    Attachment 395652
    Attachment 395654
    Attachment 395656
    Hi! bobmagnuson,
    I have a CRP4896 from cncRouterParts since 2012 ..... I'm tired 24 bearings for the Y axis .... I read your post, do you remember where you buy your stocks?
    I contact last week AvidCNC from a conversion with their linears Rail but they can't help me, I have a Old CNC
    So, if you have any links, cad, or anythings, it would be much appreciated !
    Thanks a lot
  1. Damage to linear motion rails / Bearing wear
    By benkrall in forum FineLine Automation
    Last Post: 02-21-2017, 01:55 AM
  2. Modular Steel V-Rails for Linear Motion
    By jpventuri in forum T-Slot CNC building
    Last Post: 06-30-2014, 02:33 AM
  3. linear motion rails --upside down?
    By endgrainguy in forum Linear and Rotary Motion
    Last Post: 03-24-2012, 03:07 AM
  4. Linear Carraige or Linear Motion Round Support Rails
    By newpatch in forum DIY CNC Router Table Machines
    Last Post: 03-09-2012, 12:36 AM
  5. Comparison Chart of All types of Linear Rails and Motion???
    By douglasco in forum Waterjet General Topics
    Last Post: 07-20-2008, 01:19 AM
