587,453 active members*
5,375 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > syil x2 using mach3 possibly config problem - need xml file
    Jul 2011
    Hi, I have just bought a new Syil X2 and was told that the xml file is readily available to communicate with Mach3... I have tried looking everywhere with limited success and had no response from Syil when I contacted them early last week.
    In desperation, I tried to create a new XML file using the very poor and badly spelt information within the user document that comes with the mill. This has allowed me to get the X,Y and z comms working to a degree. I am unable to get the spindle to work at all although I can hear a relay clicking???
    Has anyone had similar problems and fixed it or even better, does someone have their XML file that works which would save me a heap of trouble!
    Jul 2006
    741
    Did not know Syil made X2's
    May be they did or may be it is a kit of sorts?
    Did you try some of the SX3 profiles?
    Jun 2007
    3734
    Take some clear photos of all of the circuit boards.
    Without that, we don't know what you have.
    You say X,Y and Z work to some degree?
    Does that mean it is temperature dependent????
    Save your XML file. At least that part does something.
  1. Mach3 Config file
    By ltcjr71 in forum Charter Oak Automation Support Forum
    Last Post: 12-17-2010, 02:57 AM
  2. Mach 3 arc problem possibly
    By Chris64 in forum Mach Software (ArtSoft software)
    Last Post: 10-28-2009, 11:50 PM
  3. Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR)
    By MDF_Markazi in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2009, 08:15 AM
  4. Mach 3 driver config file
    By Drakkn in forum Mach Software (ArtSoft software)
    Last Post: 08-10-2007, 08:17 PM
  5. Drift Problems - Possibly EMC Config?
    By eeboy in forum LinuxCNC (formerly EMC2)
    Last Post: 05-15-2006, 03:08 PM
