587,754 active members*
2,786 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Looking for a reliable precision laser cutter. Any recomm.? BrightStar?
    Jul 2007
    7
    Hello,
    I am looking for a reliable precision laser cutter under 12,000 USD. I am NOT concerned about large working area size, high speed of cutting, or super high maximum power. (Power needs to be above or around 25W)
    What I need is some good precision, accuracy, repeatability. (less than 0.0004" or 10 microns).
    I am open to any suggestion of manufacturer and models.
    I am considering BrightStar Laser LG3040tt with 40w and 0.0004" repeatablity.
    Any reviews on this particular company and/or model?
    I want something reliable. This machine will be used to cut thin plastic sheets and very thin carbon fiber.
    Thank you.
    Jan 2007
    35
    Thumbs up .0004 precision in a stepper system????
    Speaking of the Chinese lasers only...
    OK I doubt very seriously that a stepper system can reproduce anything close to .0004" repeatability. It has no feedback in the system thus your errors can never be corrected by the machine so the very best accuracy you will ever get is dependent upon the precision of the drive system and the resolution of the system.
    I would bet that .005 is more real yet I doubt that any of these stepper systems can duplicate that.
    Pete
    Chinese Rabbit Laser HX6090 (60 watt) Happy with it!
    FANUC CNC (ROBODRILL / TAPE DRILL MATE) 0MC control
    Exclamation
    i also agree with pedroman however unaware as to what exactly my machines will do repeatedly i own an epilog legend ext in the 120 watt range and an rabbitt hx 6090 as well and will be honest in saying they both are exceleent pieces of equipment however the epilog is able to produce engravings with much higher resolution at higher preciseness for instance i engraved two pieces of maple with an Aztec calender on them at 300 dpi res. at 2.5 inches by 3 inches. now if you are familiar with the calender they use dots as a numerical for the days at this scale the dots were represented as one pixel in the image i honestly thought that both machines would just blob this together however surprisingly the epilog didn't it engraved it beautifully as the rabbit blobbed it together to get the rabbit to engrave it correctly i had to go to 400 and then it took about twice as long to cut it and most of the time trying to upscale images to higher resolution only leads to distortion i am currently looking at buying another epilog
    so just my 2c worth
    "The best things said should be written in stone"
    Colton www.coltonscustoms.com
    Jun 2006
    47
    Hi, just a quick note: Servo or stepper; the precision you are looking for would likely need a temperature controlled room! Thermal expansion of the metalwork will give more error. Also, the material you process will be expanding with the energy from the laser beam. Depends on the design you want to cut if this will be an issue.
    Best regards. Neil (ctrlasers.co.uk)
    Dec 2006
    15
    MD,
    I would doubt .0004 on ANY kind of machine you can buy or run OR program, if all you do is CNC. The best REAL machinist, with the BEST lathe, will not hit 4 tenths. Watchmakers with watchmaker's lathes and hand held tools may be able to do this.
    You are not.
    Here is a quote from Brightstar:
    I am sorry, it is VERY long, but it does give their reason for charging three times the price for the same machine.
    I think the concept of 50% less is very powerful indeed so here are some
    important points.
    Right now, there are many Hong Kong "trading companies" that offer
    merchandise on eBay and through web sites in the US market. It's not
    limited to laser engravers, it includes all kinds of graphics equipment like
    large format inkjet printers, vinyl cutters, heat presses etc. and probably
    extends into many other industries that I'm not aware of. For these trading
    companies, it's just about moving boxes. None of these companies have any
    support staff and mostly they don't even know much about the equipment they
    are "selling". In fact they do not have any stock and simply pass your
    order on to the manufacturer and take their profit up front. There is quite
    literally no support since when you call the trading company, they refer you
    to the manufacturer but most often the manufacturer won't give you support
    and just refers you back to the seller. You're in a Catch 22 and left
    without support. If you really want some insight on Keling Inc. look at
    their other items in their eBay store - I saw a stainless steel kitchen sink
    in there - honest! Do they look like a laser company? Just for fun, you
    might want to get their phone number and give them a call to gauge how
    helpful they might be. I'm guessing that it's a Hong Kong number (if you
    can get it). Even try asking some questions by e-mail. Make the questions
    the same ones you asked me - what kind of files, how much detail, etc. ask
    about service etc. See if you can understand the Chinese-English (we say
    Chinglish) reply that you get back (if any).
    It is important to understand the Chinese economy and mindset. Right now
    China is EXPLODING in terms of business and economy. With access to the
    internet they have discovered that there are tons of Westerners that are
    totally attracted by low prices and that these Westerners will transfer
    money by non-reversable bank transfers because the low prices are very
    attractive. Trading companies have sprung up because the Chinese have a
    good understanding that they can sell most anything on the internet. The
    trading companies make loose agreements with all kinds of manufacturers so
    that they can sell merchandise and have the manufacturer drop ship it. In
    China it's all about getting the money so the trading company is happy to
    have something to sell (even though they don't know much about it) and the
    manufacturer is happy to have somebody fishing for a sale. It's all money.
    Because we have exclusive North American distribution rights with our
    chinese manufacturer, I've tried to get all these other eBay and trading
    companies stopped from selling equipment that looks the same into the US
    market. Our manufacturer simply says "we can't control where our customers
    sell equipment". We have found that in China, honesty is a flexible concept
    and when money is involved everything can change.
    Second very important point. You will pay the trading companies up front in
    full for the merchandise. They will put it on a boat with your name and
    address on the shipping papers. When it gets to the port, two things will
    happen. First, the shipping company will try to figure out who your customs
    broker is - don't have one? Big problem #1 - If you're lucky you'll get a
    call from the shipping company (they're busy so mostly these kinds of
    problems get pushed aside) asking who your broker is. Now you've quickly
    gotta find a customs broker and file power of attorney forms etc. so that
    they can represent you with US Customs. Next, you'll have to have the
    customs broker file the Customs Entry forms (and you'll have to pay their
    fees plus the duty on the incoming merchandise). When you have any product
    that includes a laser you must file a form FDA2877 along with the customs
    forms. This is because the FDA regulates all laser products. In order to
    file the 2877 you need to have a "laser report" for the item being imported
    and this needs to be evidenced by an "assention number" from the FDA. In
    order to get the assention number you need to complete a 34 page form that
    includes all the technical details of the machine including scientific
    readings of the stray laser radiation, exact laser tube power measurements,
    schematics of the safety switches etc. Basically the 34 page FDA form
    usually turns out to be about 60-70 pages once all the supporting documents
    are done. The big problem here is that you don't have the machine - it's in
    Customs Impound - but you would need a professional testing lab to create
    the report, then file it with the FDA, wait for their approval which gives
    you the assention number which you need for the FDA2877 (remember that?).
    When we did the testing, it took 3 months and cost over $20,000 to get
    certified to import these lasers. Once the shipment hits the port, you've
    got 10 days before Customs either ships the merchandise back to the shipper
    (at your cost) or destroys the shipment. Since you've paid for the
    equipment up front if you don't get the thing through customs then you're
    out all your money. I have heard people say they've gotten stuff directly
    from China but it as far as I can tell it's mostly been prior to the
    requirements for the FDA2877 getting filed before customs can be cleared. I
    suppose you can take a chance on importing but we had big problems trying to
    get our first Chinese machines before getting certified by the FDA.
    Let's suppose you can get the machine into this country. The next problem
    is learning how to use it. This is not an inkjet printer with install
    wizards and tech support hotlines. It's a machine tool from China with
    Chinese manuals and probably little or no support. If you're an expert
    laser user, you might be able to figure things out. If you're a novice,
    it's going to be very very difficult. People think "it's a laser engraver,
    how tough can it be?" but transfer that just a bit and sit down in the
    cockpit of even a small plane - how are you going to get that thing off the
    ground? It's pretty hard to underestimate the value of training and phone
    support.
    Next, look at the warranty that these guys are offering. 1 year on the
    machine and 3 months on the laser tube. If (when)something goes wrong
    you've got to try to track down the trading company or contact the
    manufacturer and diagnose the problem. Is it a major electronic failure or
    did you just do something in the settings and the machine is fine? How much
    time and effort will you spend trying to find and correspond with the
    Chinese company? If it is an electronic failure or a laser tube goes bad,
    how long will it take to get the parts shipped (and through customs again)?
    Compare that to our warranty - 100% of the machine including the tube for 2
    years. We include all installation labor - you are responsible for mileage
    from our nearest rep or service person. If you're out of an area where we
    have someone, we'll be charging you a minimal mileage charge because we
    accept the responsibility for having service personnel reasonably close to
    you. We can even ship parts to you and walk you through the processes
    necessary for replacement if this is absolutely necessary. Any way you cut
    it, we support these machines 100% from the US with parts stocked here in
    Calif. and in South Carolina. We also have demo machines that can be
    scavenged if necessary in the odd event that something fails that we don't
    have in stock.
    Also, as I mentioned on the phone, when you purchase from us, we will ship
    the machine to you (or our rep will bring it on install day) and one of our
    tech people will show up at your door to install the machine and make sure
    it is working 100%. Before it is even shipped to you we install safety
    interlock switches and do a complete QC and operational check in our shop
    before shipping the machine on to you. This catches and correct any defects
    that were in the machine when shipped from the factory - including broken
    laser tubes etc. After our tech gets the machine installed for you he will
    run through all the operational steps and machine maintenance. Next the rep
    will spend the rest of the day - usually at least 4-5 hours - training you
    on how to use the software and working to get the best settings for the jobs
    you want to start doing (in order to make $$!). By the end of the day you
    will be able to get your artwork into the laser engraving software, make the
    necessary machine adjustments and settings and run your jobs. After
    installation, you have access to our 24/7/365 support line. Once you call
    us with a problem, we'll help figure out the solution immediately so you
    don't waste lots of time and money. Remember that I told you that I got
    into this business from the USER side - not from the importer or
    manufacturer side. For over 12 years I owned and ran a rather large
    production company making laser-cut products every day. I've owned lasers
    from all the major manufacturers and experienced every kind of bad customer
    service. It's my goal to not repeat any of those problems with my company.
    You can't make money with a machine that isn't working or if you can't get
    help making the machine do what you want it to.
    You may notice on our web site that we include a honeycomb table, the air
    assist compressor (blows air at the point of laser cutting), the exhaust fan
    and a water chiller/circulator. I'm not sure what's included in the eBay
    price but I can tell you for sure you won't be getting the chiller which is
    a small machine with a stainless water tank and radiator unit and digital
    display that controls the cooling water for the laser tube. Some of the
    Chinese machines get shipped with an aquarium pump - you supply the bucket.
    Quick failure of the laser tubes are pretty common in this scenario because
    if the laser tube is run without cooling water it will last about 10 minutes
    before it cracks or explodes. We include the chiller ($800 cost) and we
    install interlock switches so the laser will not fire unless proper water
    flow is present. This is part of what allows us to provide a two year
    warranty.
    Our prices are not negotiable because we've set them as low as possible to
    provide all the value I have explained above and to still make a profit.
    Naturally, you'll have to decide if what we provide is worth $2-3,000. As
    an "investor" I would want to make sure that my money would be purchasing
    something that would move the business forward and provide exceptional
    value. I believe that BrightStar can do just that. Please let me know if
    there are other quesitons that I can answer.
    ps. Remember that if you try to bring a machine in directly, that eBay price
    probably does not include shipping, customs duty, customs broker fees,
    warehouse fees or land shipping to get the machine from the port of entry to
    you. Even when we work in quantity, our fees run about $5-700 per machine
    to cover all these hidden costs.
    You definitely will not get such precision with a laser unless it is very small and very focused, and not to be meaured.
    I guess that he called them a Hong Kong, instead of a Chinese Mainland, company, meant that he wasn't worried about a Chinese company, or else that the Hong Kong company made worse product.
    Any body have 15 or 20 grand to spare, buy one of them US made metal tube things, HF, and see if you can make any profits?
    Cheers,
    George
    Jul 2007
    8
    Import Laser Machines
    Quote Originally Posted by gmatov View Post
    MD,
    suppose you can take a chance on importing but we had big problems trying to get our first Chinese machines before getting certified by the FDA.
    Jim Olsen
    BrightStar Lasers, Inc.
    (909) 936-5554 personal cell (best contact 24/7)
    (909) 581-4932 office
    Cheers,
    George
    Seems lot of people bought the Laser machines directly from a China manufacture and brought it in into US already. Can someone share the experiences of your importing and what documents has to be prepared for passing the US customs services. I am planning to buy a 6090 machine from Jinan. If the import process is so complicated and difficult, shouldn’t I still ask for this trouble?
    Laser123
  1. Why buy a Laser cutter when you can modify a laser engraver.
    By spacifique1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-13-2007, 08:39 PM
  2. laser cutter filtration?
    By charper in forum Education - Teachers and Students Hangout
    Last Post: 11-24-2006, 09:04 PM
  3. What laser cutter for classroom use?
    By bbuonomo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-17-2006, 11:42 PM
  4. China laser cutter
    By signbloke in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-15-2006, 04:31 AM
