587,278 active members*
3,437 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Help for tool change macro on OM VMC
    May 2008
    107
    Hi all.
    We have 04(four) VMC , with OM controler. Now we have trouble with them, because we have not any document, and all program are deleted, so we can not change the tool(pls. see attached file). Do any one have the macro( usualy named as O9001) , or have any way to change the tool.
    Pls. help us.
    Thanks all.
    Mar 2006
    61
    Fanuc OM toolchamge macro
    :9020 (TOOL CHANGE MACRO)
    IF[#1015 EQ1 ]GOTO50
    IF[#20 EQ#0 ]GOTO60
    #1100 =1
    #106 =BIN[#1032 ]
    IF[#106 EQ#20 ]GOTO40
    #101 =#4001
    #102 =#4002
    #103 =#4003
    G17 G91 G80 G0 M86
    M19
    M85
    G30 Z0.
    M82
    M84
    M07
    G28 Z0.
    T#20
    M07
    G30 Z0.
    M83
    M88
    M81
    N30 G#101 G#102 G#103
    N40 M87
    G90
    #1100 =0
    M99
    N60 #3000 =1 (M06-NO-T-CODE)
    G90
    M99
    N50 #3000 =2 (MACHINE/MST-LOCKED)
    G90
    M99
    There may be some machine specific parameters that need to be changed as this is from a Yang Eagle machine.
    Best of luck
    Stu.
    May 2008
    107
    Dear Stu M3
    Thanks you so much for your reply.
    Nov 2006
    175
    As seen from the picture, your magazine is with fixed position pots, so a.m. macro will not do the job - for T=1..6 you should first leave the tool in his pot, then pick the new one from another place. all these coordinates were maybe in some >500 variables
  1. O9000 Tool Change Macro
    By omkargupta in forum Fanuc
    Last Post: 09-17-2013, 01:00 PM
  2. A sample tool change macro.
    By gar in forum Haas Mills
    Last Post: 10-19-2012, 08:33 PM
  3. Edit Tool Change Macro Oi-MC
    By dtmtim in forum Fanuc
    Last Post: 09-21-2007, 01:34 PM
  4. O9000 Tool Change Macro
    Last Post: 09-10-2007, 10:41 PM
  5. Tool Change Macro
    By cncdiag in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-26-2007, 08:20 PM
