587,698 active members*
3,633 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Running single phase motor using VFD
    Sep 2005
    8
    I plan to buy 1-phase to 3-phase VFD for spindle speed control for upcoming 3-phase motor.
    Before that I would like to know is it possible to get 60 Hz single phase out from that VFD. I'm living in 50 Hz world but I have one single phase motor which requires 60 Hz to run correctly. Any specific wiring for this?
    24220
    You should be able to run the motor on 50hz if you can live with the reduction in rpm.
    Al.
    Apr 2007
    6
    A VFD is a Variable Frequency Drive , so the output can vary between 0 and a maximum frequency, generally 400Hz on a three phase motor,not on a one phase.
    Sep 2005
    8
    Al.
    Actually I can run the motor with 50Hz but it gets very hot. I read about this before in this forum. It is because of something I didn't exactly understand, related to magnetism.
  1. Can I convert single phase motor to three phase?
    By Jim Estes in forum Phase Converters
    Last Post: 06-04-2020, 02:52 PM
  2. Replies: 12
    Last Post: 10-13-2009, 03:53 AM
  3. VFD for a single Phase motor!!
    By Yepez in forum Servo Motors / Drives
    Last Post: 08-11-2009, 12:53 AM
  4. ? about vm-16 or vm-17 running single phase?
    By dccamp in forum Milltronics
    Last Post: 02-28-2009, 11:01 PM
  5. Need single phase motor help
    By bob1112 in forum CNC Machine Related Electronics
    Last Post: 02-25-2008, 02:48 AM
