587,453 active members*
5,871 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > A2100 Power Supply Malfunction
    Apr 2006
    4
    We have a Cincinnati Falcon lathe with an A2100 control that has given us a 'Power Supply Malfunction' error a few times in the past few days.
    System Fail 8004E:
    Power Supply Failure
    Cause: There appears to have been a malfunction of the power supply for the control system, casuing the Realtime Processor to reset and restart.
    Does this mean the power supply in the Vickers Computer, or the 24v power supply that runs the relays and opto-isolators?
    Benjamin Jennings
    Sep 2009
    11
    I believe it's referring to the PC power supply in the A2100. Those were pretty cheap Taiwanese units (but they passed regression testing, when some other cheapies didn't). It's an off-the-shelf PC supply. Take it to your local computer supply house and have them match it up.
    The A2100 boots just fine with no other power supplies connected, so the system fail must be coming from the PC P/S failure.
    Ron
    Jacobson Machinery
    A2100 Flash Drive - replace the failure prone HDD in your A2100 or A950 CNC:
    http://www.jacobsonmachinery.com/Por...FlashDrive.pdf
    Apr 2006
    4
    That was what I'd suspected, the lathe is on it's 3rd or 4th power supply now, the other ones all exibited different failure modes, but this is the first one I've seen where the control actually complained about it.
    Benjamin Jennings
  1. How'd you supply your power supply?
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 08-28-2011, 11:13 AM
  2. A2100 auto power off possible?
    By sunnybank in forum Cincinnati CNC
    Last Post: 09-18-2009, 01:26 PM
  3. More power from switching power supply
    By R.thayer in forum CNC Machine Related Electronics
    Last Post: 03-11-2007, 02:03 AM
  4. Power supply help
    By bigvinney in forum CNC Machine Related Electronics
    Last Post: 01-21-2006, 02:42 AM
  5. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
