I plan to do a lot of aluminum work with my diy router if that has any effect on responses. I'm designing my router to be adjustable for the squareness of xy/yz/xz but I'm looking for values for what's good and what's not. The squareness of xy is likely the most important since most of what i'll be doing with be 2.5 d in aluminum plate. Also what is a good squareness for the spindle itself. By this I mean the linear rails can all be perfectly square so a given point on the cutting tool can move precisely but the spindle itself can be out of square with the actual direction of movement.(i'll make pics if that's hard to understand). My questions are what are good values for squareness for xy/xz/yz and spindle squareness with the rails in xz/yz planes. My machine will have a cutting area of 15x15x4 and will be used for work that is hopefully accurate within .001" in all dimension for anything i cut(mostly just for bragging rights, i will likely never "need" that precision). Thank You
