587,657 active members*
7,742 visitors online*
IndustryArena Forum > CAM Software > SheetCam > Post Processor Files > Aspire post processor (pp) for generic 6090 CNC using RichAuto B58 4th axis rotary
    Aug 2016
    5
    Group, I need your help with either a correction in Aspire 10, pp file, or RichAuto B58 dsp settings.
    Background:
    I decided to do an upgrade from RichAuto A11 3axis (x,y,z, rotary x wrap around y) to B58 4axis (x,y,z,a with additional drive) on Chinese 6090 CNC. A axis (rotary) pulse set to 13.3 pluses/mm for 0.5 deg turn on rotary. Used Axiom Elite pp for Aspire b/c they use the same DSP (took the line # feature out). Confirmed DSP is able to move all axis via the pad.
    Created a test file output from Aspire using a rotary project with a simple wrap around on-line profile path to check 360 deg rotary turn:
    G91G28X0Y0Z0
    G40G17G80G49
    T1M6
    G90G54
    G0X0Y0M3
    G0A0.000Y0.000S16000
    G00A0.000Y0.949Z5.080
    G1Z-3.000F254.0
    G1A360.000F762.0
    G00Z5.080
    G28G91Z0
    G49H0
    G28X0Y0
    M05
    M30
    When run on the RichAuto B58 DSP, the spindle fires up, goes down, but then goes back up without doing the rotation. I do not see anything wrong with the code. Ran another file with a spiral that showed 4.25 complete turns based on spacing and Y distance but when I run it, Y distance is met but A axis only turns about 90 deg.
    So what am I missing? Anyone have the config for the B58 or a pp that they know translate correctly from Aspire 10 to gcode, or is it a setting I am overlooking?
    Thank you in advance for any guidance that can get me past this hurdle.
    Aug 2020
    Re: Aspire post processor (pp) for generic 6090 CNC using RichAuto B58 4th axis rotar
    command M03[S] must be together
    in you code this is in different line
    some machine use [S]M03
  1. 4 axis rotary aspire
    By cilim in forum Aspire
    Last Post: 09-03-2019, 06:56 PM
  2. In need of a Generic Mill Turn post processor SOLIDCAM
    By kolias_89 in forum Post Processor Files
    Last Post: 04-14-2019, 08:08 AM
  3. Chinese 6090 on Richauto DSP
    By andrewdenhaan in forum Chinese Machines
    Last Post: 01-07-2016, 07:41 AM
  4. 6090 4 AXIS ( 3 + 1 ROTARY) POSTPROCCESOR
    By yogev kat in forum G-Code Programing
    Last Post: 10-08-2014, 03:10 PM
  5. Generic Post Processor for Powermill 10?
    By microbeast29 in forum PowerMILL
    Last Post: 02-06-2011, 01:20 PM
