587,131 active members*
3,027 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > rack and rack & pinion with off the self planetary gearbox
    Apr 2006
    1016
    Has anyone see and designs with r/p with off the shelf planetary gearbox
    Try to get some ideas for tensioning the spur gear into the track with a planetary gearbox?
    24223
    Apr 2006
    1016
    which picture had the rosta tensioner
    Im planing on using a gear box planatery gearbox direct drive to the rack and pinion, dont see how the tension to maintaned on that rack? please explain.
    24223
    In the forum link, post #13 you can see the Rosta component I adapted on the R.H. side.
    All of the pictures shown use the same device.
    The Rosta parts used are DR-A27X100 BR27 & WS18-27.
    These are tensioned by a twisting action and the centre axis can be pre-tensioned to ensure positive engagement, the assembly basically hinges on the Rosta device, these use high tensile rubber as the tension medium.
    A picture of the cross section is shown at the top of every page in the Rosta pamphlet PDF.
    Al.
    24223
    I should have added I held the centre post locked and the motor drive plate was attached to the outer part of the Rosta and allowed to pivot around the locked pin, under tension.
    Al.
  1. calculatiing pinion size for rack and pinion setup
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 08-06-2015, 11:18 AM
  2. Rack & Pinion
    By captainkirk in forum DIY CNC Router Table Machines
    Last Post: 06-27-2008, 07:49 PM
  3. Rack and Pinion
    By Locster13 in forum Linear and Rotary Motion
    Last Post: 02-24-2006, 04:07 PM
  4. rack and pinion
    By senor J. in forum Linear and Rotary Motion
    Last Post: 11-17-2005, 11:21 PM
  5. Rack and Pinion
    By Hillman in forum Linear and Rotary Motion
    Last Post: 08-09-2005, 10:14 PM
