587,925 active members*
3,693 visitors online*
Results 1 to 12 of 12
    May 2012
    30
    UC400ETH Not Connecting
    Hi All,
    I just put my license file in the UCCNC folder and opened UCCNC and it said I needed to do a firmware update so I did. I then opened UCCNC again and got this message:
    “The application lost the connection to the motion controller device. Check the connection. The application is closing now! Save offsets?"
    I reset the UC400ETH and tried again and got the same error. I can access the UC400ETH with the utility and set the ip address just fine. There are not any ip conflicts on the network.
    Any suggestions?
    Chuck
    Re: UC400ETH Not Connecting
    Make sure you rename the licence file. You need to remove the serial number from the license file name.
    Arturo Duncan
    Welcome to CNC4PC
    Apr 2014
    59
    Arturo,
    That's not true. It is normal to have more licence file in UCCNC folder. UCCNC checks for the filename like "UCCNClicense*.txt", so this way you may store more licence files. See my folder:
    Apr 2014
    59
    Chuck,
    How did you reset UC400? Did you press reset while no power on UC400 and released only after the power was on again? The UCxxx_utility should find the UC400 if they are on the same network, regardless of the IP adresses. Be sure to connect your PC with wired network, because wifi will not work.
    May 2012
    30
    Changed the license file, removed the SN and it worked! Thanks Arturo
    Yes I pressed the reset button with the power off then kept it pressed and powered on the unit.
    I imported my Mach3 config and all looks good for the most part, I do need to make some tweaks.
    Thanks for the Help!
    Chuck
    Apr 2014
    59
    I think, that the elapsed time resolved the problem. If there is a problem with the licence file, you get a licence error, not communication. Maybe, the UC400 needed more time to find the network...
    May 2012
    30
    So I got home this evening and tried to open UCCNC and got the same error again. Thoughts?
    Jun 2015
    943
    It sounds like a network problem. Do you have direct wire or network connection to the controller?
    Post your settings from the utility tool and the network ipconfig settings.
    May 2012
    30
    UC400ETH:
    IP: 192.168.5.20
    Subnet Mask: 255.255.255.0
    Gateway: 192.168.5.1
    and yes my LAN is 192.168.5.x
    So I just changed UC400ETH ip to 192.168.5.10 and it worked, surely I don't have to change the ip address everytime?
    Chuck
    Jun 2015
    943
    Ofcourse you don't have to change the IP address every time. You have to do it once, but you have to do it properly.
    The IP address of your computer must fit the IP address and subnet mask of your controller and then it will work.
    If your LAN card is doing DHCP then check the DHCP option in the controller and then the LAN card will give an IP to the controller.
    From the Utility, you need to enable DHCP for the UC400ETH.
    May 2012
    30
    Why do I have to use DHCP? Will it not work if I assign a static IP to the UC400ETH? The UC400ETH is plugged into a switch on my network. The router on my network has DHCP enabled for oddball things connecting but I do use static IP's for several things on the network.
    Chuck
  1. Ordered the UC400ETH
    By wjbzone in forum Controller & Computer Solutions
    Last Post: 01-28-2019, 04:21 PM
  2. UC400ETH questions
    By stampsm in forum UCCNC Control Software
    Last Post: 08-18-2016, 08:52 PM
  3. UC400ETH network setup
    By bpratl in forum UCCNC Control Software
    Last Post: 06-19-2016, 10:09 PM
  4. Mach3 UC400eth and joypad
    By silverdog in forum UCCNC Control Software
    Last Post: 04-21-2016, 09:14 AM
  5. UC400ETH and Mach3
    By vmax549 in forum UCCNC Control Software
    Last Post: 04-08-2016, 05:24 AM
