587,426 active members*
4,148 visitors online*
    Nov 2007
    Tree VMC 1060
    We have a Tree VMC1060 and keep having feed problems (we feed from a laptop). We are using communicate to feed it. The problem is that it stops every once and a while. Sometimes it will run fine and sometimes not. We have tried new cables and multipe computers. Has anyone had any similar problems?
    Apr 2003
    76
    Smile
    Sounds familar I tried mold making on my tree VMC 1050 and had a lot of problems.
    Not a machine issue but a controller issue. Mine was a Yasnac MX3. Found the problem after a lot of calls and playing. It is generaly a parameter setting in the communication settings but you will ned the books to find it. What type of controler you have and what type of DNC softwater you using?
    What are your communication settings and wiring configuration?
    Post asmuch information you can and we might be able to help.
    If its not broken you are not going fast enough
    Jun 2004
    26
    What program are you using? Make sure your communication handshake is setup right. In most cases you can throttle down the computers output speed aswell. Is this a Dynapath control too?
  1. G-Post for Integrex 1060
    By massud in forum PTC Pro/Manufacture
    Last Post: 12-08-2009, 04:18 PM
  2. tree 2uvr-c tree mill
    By willcofab in forum Tree
    Last Post: 06-11-2009, 07:40 PM
  3. Zps Tree Vmc 1060 Way Cover
    By envisioneng in forum Tree
    Last Post: 07-25-2007, 05:33 PM
  4. Integrex 1060 - Need Post-Processor
    By massud in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-12-2007, 01:57 PM
  5. num 1060 or the like
    By sc_crasher in forum Fanuc
    Last Post: 01-12-2006, 02:11 AM
