587,495 active members*
2,903 visitors online*
IndustryArena Forum > MetalWorking > Bending, Forging, Extrusion... > press brake can't find reference point
    Oct 2010
    30
    We have problem. Press brake GASPARINI x-press 100 can't find reference point only on Y. Beam goes through limit switches without any effect. Switches passes signal to the electrical box and laser box.
    Aug 2010
    hi,
    what cnc is built on your machine and is it a servo hydraulic machine or a torsion pressbrake ?
    you said the switches passes the signal to the electrical box, maybe you have an relais in the control cabinet which is not working or have contact problems, so that the cnc get no signal to switch off the valves and stop the upper movement... but its just a guess from side...
    if you have a servo hydraulic machine, you have 2 measuring scales on y1 and y2... maybe you can check it...
    thats all for now...
    regards
    Oct 2010
    30
    Re: press brake can't find reference point
    Problem was in Y2 measuring scale..
  1. Converting Conventional Hydraulic Press Brake to CNC Press Brake with PC
    By aadityadengle in forum Uncategorised MetalWorking Machines
    Last Post: 08-13-2023, 05:23 PM
  2. Retract to reference point
    By banflescrum in forum Mastercam
    Last Post: 01-27-2021, 05:34 PM
  3. Lost reference point
    By arturonaupa in forum Fanuc
    Last Post: 05-29-2013, 11:18 PM
  4. Selecting Press for home shop press brake
    By tikka308 in forum Bending, Forging, Extrusion...
    Last Post: 12-29-2009, 05:51 AM
  5. NorthStar Press Brake For 20 Ton Shop Press anyone ever use one?
    By dsmdude in forum Bending, Forging, Extrusion...
    Last Post: 04-13-2007, 10:01 PM
