587,092 active members*
5,784 visitors online*
    May 2016
    4
    Kflop Robot 7/8 axis
    Hello everyone, I am interested in buying a KFLOP controller. before buying I have some questions for you.
    I apologize for my English that is translated by Google, I hope you can understand.
    The use of Kflop I have to do is to control a robot to 7/8 axes + instrument, driven by stepper motors.
    the software is able to handle the 8 axes of control, with Gcode or other system? the software can be used without having to make changes?
    May 2016
    4
    Re: Kflop Robot 7/8 axis
    May 2006
    4047
    Hi Ibis6,
    KFLOP itself is capable of 8 axes of simultaneous coordinated motion. However our GCode Interpreter, Trajectory Planner, Kinematics libraries are currently limited to 6 axes. The 6 of 8 axes can be changed on the fly. Also additional axes beyond 6 can be slaves, tool changers, spindles, etc...
    HTH
    Regards
    TK
    http://dynomotion.com
    May 2016
    4
    thanks for the reply. in effect, the robot has 6 axes and 1 motor for the gripper. so if I understand you can handle 6-axis and the engine of the clamp? if I wanted to manage 8 axes that software should I use?
    May 2006
    4047
    Hi Ibis6,
    For only 6 axes plus 1 gripper you should be ok. You could use our KMotionCNC Application for XYZABC. You might handle the gripper with an M Code configured to tell KFLOP how to set the gripper position.
    To do 8 axes of simultaneous coordinated motion you would need to write your own GCode Interpreter, Trajectory Planner, Kinematics, etc (or expand on ours) to issue low level 8 axes KFLOP commands such as:
    Script Commands. That would be a significant amount of work.
    Regards
    TK
  1. Need a any postprocessor for 6 axis arm robot
    By Lucky_hunter in forum PowerMILL
    Last Post: 07-31-2013, 11:20 AM
  2. DIY 6 axis robot arm CNC
    By Lucky_hunter in forum Videos
    Last Post: 04-01-2013, 02:40 PM
  3. software for 6-axis robot
    By buchin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-30-2012, 01:20 PM
  4. robot 5 axis cnc
    By aventtini888 in forum Maintenance DIY Discussion
    Last Post: 10-13-2011, 04:53 PM
  5. Could Bob CAD/CAM work with 6 axis robot??
    By calkai1 in forum BobCad-Cam
    Last Post: 12-04-2008, 01:42 PM
