587,427 active members*
7,024 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > distance between computer and machine?
    Jun 2009
    146
    Hi, a random thought..
    My laser machine is about 20 feet away from my computer. So which is the best option for positioning the controller
    1/ A 20ft parallel cable to the controller inside the machine and short wires to the steppers
    or
    2/ A 2ft parallel cable fron the computer to the controller and then 20ft of cable from the controller to the stepper motors
    I am wondering where steps are most likely to be lost?
    rabbit / ls3040
    Oct 2005
    2392
    A 20ft parallel cable shold be fine.
    Many years ago (back in the Dos days) I made a 60 foot parallel lead for doing data transfers between PCs, I used some 16 core shielded alarm cable, which basically was nothing special in cable terms. It gave years of good use transferring data at the top transfer speed, so don't be afraid that a 20 foot parallel cable is going to cause too many problems.
    PS. It was also common in office buildings in the '80s to have very long parallel cables in the walls for remote printing as those big 7pin printers were NOISY and kept in rooms far away.
    Jun 2009
    146
    ok thanks
    I read about an 18ft maximum somewhere but I guess it depends on the use its being put to. Ill try 20
    rabbit / ls3040
  1. Need computer to machine help
    By Larry Myers in forum Sharp CNC
    Last Post: 09-11-2019, 09:04 AM
  2. Connect CNC Machine To Your Computer Wirelessly
    By WCSC in forum News Announcements
    Last Post: 07-27-2009, 04:02 PM
  3. computer control machine pot
    By Karl_T in forum CNC Machine Related Electronics
    Last Post: 06-20-2009, 06:09 PM
  4. Computer to machine help needed
    By Larry Myers in forum Controller & Computer Solutions
    Last Post: 08-21-2008, 05:37 PM
  5. Setting up computer/machine communication
    By MrWild in forum Dolphin CAD/CAM
    Last Post: 06-04-2008, 12:56 AM
