587,698 active members*
3,741 visitors online*
Results 1 to 12 of 12
    Sep 2008
    27
    RAM compensation 15M
    I'm trying compensate the Ram error with vertical axis movement in a Fanuc 15M. The parameters are 5481, 5491, 5501-5504, 5551-5554, but how to configure the parameters? what kind of data for compensation point number?
    Sep 2008
    27
    please i need help, thanks!
    Jun 2008
    1511
    Do you have the parameter manual for this control? I have never had to do the procedure so I will not be able to explain it, but I have the parameter manual that gives examples of how to do it. LMK
    Stevo
    Sep 2008
    27
    great, can you send me the example or a scan of the page?
    tankyou very much!!
    Jun 2008
    1511
    I hope this helps. Let me know if there is anything else that you need.
    Stevo
    Attached Files Attached Files
    Sep 2008
    27
    Thanks again Stevo!!
    Jun 2008
    1511
    Your welcome. Any time.:cheers:
    Stevo
    Feb 2007
    314
    IS THERE A FUNCTION LIKE THAT ON A O-MD??, I KNOW IT FOR PITCH ERROR, BUT FOR STRAIGHTNESS I THINK THERE IS NOTHING.
    Jun 2008
    1511
    I am not sure I will check. I don't know if it matters but is it a lathe or machining center? I show the manuals for the Oi series and the O-mc. I do not come up with anything on the search for a O-MD
    Stevo
    Feb 2007
    314
    Quote Originally Posted by stevo1 View Post
    Stevo
    IT'S A MACHINING CENTER
    Jun 2008
    1511
    The only thing I got is parameters for O series. I could not find anything on straightness comp for that control O-md. I will do some more searching when I get time and let you know if I find anything. I have a lot of stuff on the Oi series but SOL on the O.
    Stevo
    Sep 2008
    27
    option enable?
    i tried configure the straitness compensation (in the 15M) but with no success and believe that i tried several times with several configurations of points, axis, compensations!... in one of the pages that is posted talks about the option that must be enable (page 240 par. 1). do you now how can i see if the machine have this option enable or how can i enable this option?
    Bruno
  1. cutter compensation
    By functionbikes in forum Tormach Personal CNC Mill
    Last Post: 06-17-2008, 08:39 AM
  2. Tool compensation
    By bg_izio in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-04-2006, 02:40 AM
  3. Cutter Compensation?
    By Joe Petro in forum Autodesk
    Last Post: 03-08-2006, 07:04 AM
  4. Backlash Compensation
    By utengineer04 in forum MetalWork Discussion
    Last Post: 04-26-2005, 05:42 PM
