Hello,
I am trying to help a friend fix his Okuma MC-5VA mill. It has a toolchanger issue. When machine is first started up toolchanges work properly but as time goes on the toolchanger arm will hang mid way, sometimes it will grasp the tools and hang. He can succesfully complete ~2-3 toolchanges before this happens. Currently he is just running it as a 1 tool machine or if he needs to change tools, he does so by hand which is not as easy as it sounds because of the heavy 50 taper holders.
The machine is a 1984 model w/ OSP5000M green screen control. Can someone point me in some direction on this? I would really like to help him out but don't know anything about the machine. First guess is maybe a limit switch but the fact that it works only while the machine is cold makes me wonder if there is some air or hydraulic adjustment that needs to be made?
