587,125 active members*
4,485 visitors online*
    Dec 2007
    236
    Setting Z Coordinates
    I am new to CNC and New to Mach3
    I am face milling a part .030" from the top of my vise. What I have been doing is using a brass .030" feeler gauge between the top of the vise and the face mill tooth. Zero axis lower the table .315" ( this is the Max depth cut last pass) then reset the axis to Zero. Is there a way just to enter .315" in the DRO and making it accept that value?
    I know I am missing something, just cannot seem to find how to do it.
    Thanks.
    Ark1
    TonyK.
    Hit enter after typing in the number.
    Dec 2007
    236
    Thanks.
    Gerry thank you.
    The learning curve is frustrating at times. I think you bailed me out with the same answer in the Mach3 Mill Addons.
    One day I will get it.
    Once again thank you.
    Ark1
    TonyK.
  1. G92 coordinates
    By monaro mike in forum Fanuc
    Last Post: 08-07-2018, 06:27 PM
  2. IMG to Coordinates
    By YoJoey in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-28-2011, 09:57 AM
  3. Setting the machine x,y,z coordinates
    By surrealism in forum Taig Mills / Lathes
    Last Post: 06-17-2010, 04:32 PM
  4. setting work coordinates through program
    By lsrengineering in forum Haas Mills
    Last Post: 06-08-2010, 03:07 PM
  5. Trying to set origin coordinates
    By LockTech in forum Uncategorised CAM Discussion
    Last Post: 11-26-2009, 06:23 AM
