587,409 active members*
3,307 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > inside arcs with comp doing "loop de loops"
Results 1 to 12 of 12
    Apr 2009
    21
    Whenever I do an inside arc on my FANUC 10m, I get full circles then it goes on it's way to do the program as programmed.
    It happens with I, J, and R.
    I recently accidently erased all my parameters and re-entered them through a parameter list from leadwell
    2932
    Why not post an example of the code so we can take a look?
    Apr 2009
    21
    Quote Originally Posted by dcoupar View Post
    O100
    (MTOOL T9 S1 D.5 H5. DIAM_OFFSET 9 = .25)
    G90 G80 G40 G20 G17
    G00 G91 G28 Z0.
    G91 G28 X0. Y0.
    T9 M06
    S374 M3
    G00 G90 G54 X-.3 Y0.
    M01
    G43 H9 Z.1 M08
    G01 Z-.5 F.9
    G42 D59 Y.3 F50.
    G02 X0. Y0. I0. J-.3
    G01 Y-2.
    X.4
    G03 X.5 Y-1.9 I0. J.1
    G01 Y-1.8
    G02 X.8 Y-1.5 I.3 J0.
    G01 X1.9
    G03 X2. Y-1.4 I0. J.1
    G01 Y-.6
    G03 X1.9 Y-.5 I-.1 J0.
    G01 X.8
    G02 X.5 Y-.2 I0. J.3
    G01 Y-.1
    G03 X.4 Y0. I-.1 J0.
    G01 X0.
    G02 X-.3 Y.3 I0. J.3
    G40 G01 X0.
    G90 G00 Z.1
    G91 G28 Z0. M05
    G91 G28 X0. Y0.
    G90
    M30
    2932
    Does it do this on the lead-in G02 arcs also? I assume it worked properly before the parameters were erased?
    Apr 2009
    21
    Yes, any arc where the cutter's 'inside' the arc.
    Apr 2009
    21
    I found it!!!
    Param 6010 was too high!!! I'll run a few programs and see how it goes.
    2932
    Way to go!
    Apr 2009
    21
    Way to go!
    I get a little apprehensive with just plugging away. Idon't want to wreck anything.
    Are you familiar with parameters for spindle gear selection?
    Up to 1000 RPM, my speed quadruples. Over 1000 (even 1000.5), it's just fine.
    2932
    My 10M manual is 180 miles away, sadly. I'll take a look when I get home this evening. What make/model machine is this?
    Apr 2009
    21
    Leadwell
    Model MCV 550D
    Series: 865282
    Mfg. Date: Jan 1986
    Fanuc 10MA
    Mfg. No: 5983
    I need the spindle speed parameters. They are 5600 to 6000
    2932
    Just out of curiosity, have you contacted Leadwell? They may have copies of the parameter list for that machine.
    Apr 2009
    21
    I have a copy they sent me. It's missing the spindle ratios, though.
  1. G320 "common" or "+5vdc" why do they vary?
    By beezerlm in forum Gecko Drives
    Last Post: 01-12-2008, 11:00 PM
  2. rfq: 1 1/4" threads on inside of round tube
    By dsmdude in forum Employment Opportunity
    Last Post: 04-26-2007, 04:25 AM
  3. 3D image "cracked" inside glass
    By moyesboy2 in forum Glass, Plastic and Stone
    Last Post: 08-04-2006, 07:42 AM
  4. tracking down MDI "hang" with loops & macros
    By howling60 in forum CamSoft Products
    Last Post: 03-02-2006, 09:28 PM
