587,427 active members*
4,810 visitors online*
    Jun 2005
    23
    Anyone used Polythene pad slides for T slot extrusion
    Have any of you guys used these bearings for an X Y assembly, they are designed to slot directly on to T slot aluminum extrusion. The use UHMW-PE (Ultra High Molecular Weight Polyethylene) bearing pads.
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=370188940426
    Cam.
    Jun 2005
    23
    Jun 2006
    16
    I and others have used them, but they are pretty much crap when it comes to using them on a machine axis if you want any speed at all. They have too much friction when they are set up for no slop or too much slop with little friction.
    Jun 2005
    23
    Thanks for the confirmation. Moving right along then does anyone do a skate bearing linear slide for ally T slot extrusion then ? I notice the guys at http://www.cncrouterparts.com/ do something very close to this. I guess skate bearings straight on ally extrusion would be a bad match of material hardness.
    Cam.
  1. Extrusion Help
    By wilson248 in forum Bending, Forging, Extrusion...
    Last Post: 04-15-2009, 03:16 PM
  2. cutting a slot with a t-slot cutter
    By cncuser1 in forum Mastercam
    Last Post: 09-10-2008, 03:02 AM
  3. T-slot Router Bed Extrusion
    By gotswrv in forum Want To Buy...Need help!
    Last Post: 07-11-2008, 02:16 AM
  4. Replies: 7
    Last Post: 04-12-2007, 03:00 AM
  5. Linear Slides v/s rail slides
    By bryanrabb in forum DIY CNC Router Table Machines
    Last Post: 03-28-2006, 03:45 AM
