587,518 active members*
3,331 visitors online*
    Jul 2007
    25
    machining elliptical punch and die
    I need to make an elliptical punch and die, and I have not done much 3D machining.First can you comp a ballmill in Y and Z the way you would in X and Y
    a regular endmill ?Second if you cant use cutter comp how do you write the comp into the toolpath for the die? For the punch I am thinking that I could program the ellipse wider by the cutter diameter.For the die I'm not sure what I should comp and where.Mind I don't have CAD CAM software and I am using a FANUC Oi-MC control
    Jul 2008
    116
    The only way that you could comp it is useing scaleing feater of the control there are sevral post on here about it in resent days.
    Kyle
    http://http://www.cnczone.com/forums...ad.php?t=84627
    You must remember that 99% of my posts are Bullchit!
    Jul 2007
    25
    I'm having trouble with that link
    Jul 2008
    116
  1. Punch?? or What??
    By ShayArnett in forum MetalWork Discussion
    Last Post: 03-20-2010, 03:28 AM
  2. Punch Presses
    By David Cockburn in forum Uncategorised MetalWorking Machines
    Last Post: 10-11-2007, 05:00 PM
  3. cnc punch
    By newrock in forum G-Code Programing
    Last Post: 08-22-2007, 03:17 PM
  4. RFQ punch holer
    By fastolds in forum Employment Opportunity
    Last Post: 11-29-2005, 11:45 PM
