587,424 active members*
3,931 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > fanuc tape drill g31 skip input pin? 0-m
Results 1 to 9 of 9
    Sep 2012
    182
    I don't have a ladder diagram and want to find the skip input.
    some info says it is a dedicated input on connector M18 pin 49.
    if you have a tape drill or an early robo drill could you tell me what pin the skip signal is on.
    Nov 2006
    418
    My schematic shows TM3 terminal 21 & 22. This is where my tool probe is connected, I did the installation.
    I don't know where M18 is, I've never ran across that designation on any of the I/O terminals on my machine. What info is it you found that in?
    Sep 2012
    182
    thanks. I thought that the wiring may be similar on other tape/robo drills as I had a service technician come in with a later model wiring manual and it was the same as my old machines wiring.
    I don't think I have the TM3 connector but I'll have another look just in case.
    Nov 2006
    418
    What year specifically is the machine in question? Is the control a 0m-c or 0m-d?
    Sep 2012
    182
    0m-a 1986 but the wiring was the same as an 0m-b from the early 90's
    Sep 2012
    182
    I ended up testing connector M18 pin 49 and it is the skip input on my 0m-a
    Nov 2006
    418
    Good deal, it's easy then. You can hook that up simple enough, the next matter is a macro to use the skip input. Do you know if you have Macro A or B (if B was even available on an 0m-A I don't know).
    Sep 2012
    182
    I have macro A. it will work but will be painfully slow, since it is a one line per operation code.
    Nov 2006
    418
    Still better than nothing though...
  1. help with Fanuc tape drill mate
    By landslide1 in forum Fanuc
    Last Post: 11-10-2012, 01:46 AM
  2. Fanuc FV Tape Drill
    By brakmaren in forum Uncategorised MetalWorking Machines
    Last Post: 04-05-2009, 02:40 PM
  3. Problem with ATC of Tape Drill FANUC 6MB
    By david_chen in forum Fanuc
    Last Post: 02-11-2009, 04:05 AM
  4. Fanuc Tape Drill Toolholders
    By troberts in forum Want To Buy...Need help!
    Last Post: 01-23-2009, 01:26 AM
  5. fanuc drill tape center, Makino mc65
    By rathi_vk in forum MetalWork Discussion
    Last Post: 11-25-2008, 04:03 PM
