587,450 active members*
3,802 visitors online*
IndustryArena Forum > Maintenance in General > Maintenance DIY Discussion > Small screw with back and forth motion
    Jun 2010
    98
    Not sure how to say this, but I will give it my best shot. I want to make a small contoller like a remote, "can be wired" That will control a DC motor that is attached to a leadscrew that runs a carriage on a linear rail.
    I want this carriage to travel between two limit switches about 6 inches apart. I want The machine to travel the 6 inches one direction and then stop, when I throw the switch/hit button, I want the carriage to reverse direction and come to the other limit switch and stop.
    So basiclly I want something that has is hooked up for a double pole double throw switch all in a nice little box. Anyone know where to find what I am looking for. Radio shack and the local electronics store were not helpful.
    Mar 2006
    2712
    Sounds like a miniature garage door opener. Can you get that kind of circuitry?
    Dick Z
    DZASTR
    Jan 2007
    42
    Buy a box, mount a dpdt switch in to power the motor forward or reverse. Put normally closed limit switches in series with the motor so it stops at either end. Put a diode across each limit switch so it only stops the motion in that direction.
    Jan 2006
    2985
    Quote Originally Posted by nophead00 View Post
    This is the easiest way to go. I have used this method on a similar linear axis with stops at top and bottom. Cheap, simple, reliable.
    Matt
  1. Small nicks in ball screw
    By guru_florida in forum Linear and Rotary Motion
    Last Post: 08-12-2010, 11:30 PM
  2. 1 Small steel screw with collar.
    By diyengineer in forum Employment Opportunity
    Last Post: 04-26-2010, 07:47 AM
  3. comercial/home made screw for continuus linear motion?
    By fxs in forum Linear and Rotary Motion
    Last Post: 10-29-2009, 06:19 PM
  4. 1/4" lead screw for Z - too small?
    By analogman in forum DIY CNC Router Table Machines
    Last Post: 11-03-2008, 01:52 PM
  5. Kerk Motion RGS (Rapid Guide Screw)
    By Losos in forum DIY CNC Router Table Machines
    Last Post: 01-26-2005, 05:38 AM
