I need this shape and another one slightly smaller cut out of 6061-t6 aluminum.
.05" thick. Two of each.
I will supply a dfx file in the units of your choice.
---The dimensions are shown to the 4th decimal place but the closest 0.000" is fine-----
All you need is a printer, some tape and a pair of snips.
The parts need to be made by machine. The parts are incorporated into the construction of skis with tight tolerances.
what is this used for? what tolerance do you require?
They are for the base of skis, at the tips
Here is a picture of what the part will look like.
The tolerance is .005" I guess.
Thanks to all who replied and Pm'd but the part has been put on hold.
