587,220 active members*
3,046 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > I have the CNCFusion Kit for the X3, Now what?
Results 1 to 10 of 10
    Feb 2007
    61
    Well, being as the instructions on their site are incomplete, do I need anything else?
    It seems I have some bearings in the stock ACME screws that came with my X3, but do I need to go out and buy any extra bearings or anything else to get the kit properly installed?
    Thank You
    Feb 2007
    61
    is anyone able to help me out here quick?
    Apr 2005
    1778
    Sorry, I can't help. Try e-mailing CNCFusion and asking them.
    Alan
    Feb 2007
    61
    i did in fact already e-mail them and he didn't really say much.
    Dec 2005
    430
    from the conversions i have seen, u use the stock bearings and adjust preload by a locknut (atleast that is what i have seen on the x axis)
    May 2007
    6
    I just finished my X3 conversion with the same kit, and yes - the instructions are quite incomplete.
    You should have received the motor mounts, two shaft collars, and some Lovejoy couplers; these and some miscellaneous hardware (also included) should be all you need.
    Feb 2007
    61
    after building the machine and upgrading the parts its become obvious to use the bearings supplied with the mill.
    its also become obvious that these aren't the best bearings, and now I understand upgrading to angular contacts is the way to go.
    well damn. I don't want to take the axes apart again. I suppose I'll upgrade them if backlash becomes a concern.
    May 2007
    6
    Bearings and backlash
    Affirm, affirm - the X3 bearings are junk. And preload is 'adjusted' with a pry-bar while tightening up the shaft collars.
    I wound up with backlash in the 4 to 6 mil range; that's comparable to what the mill had before I installed the kit.
    FWIW: it's possible to leave the handwheel on the X axis; don't know why the instructions specify that it be removed.
    May 2006
    14
    Crap bearings
    Ok, Need to change the bearings. Does anyone have information on what replacement bearings to get? part no. source etc.??
    Sep 2006
    480
    Hello Ron,
    I see it's been awhile with no replies, did you ever replace the bearings? If so which ones did you end up going with?
    Bob
  1. CNCFusion Kit Install photos
    By Jay C in forum Benchtop Machines
    Last Post: 04-26-2007, 10:30 PM
  2. CNCFusion 9x20 lathe conversion?
    By thumper650 in forum Mini Lathe
    Last Post: 04-24-2007, 07:00 AM
  3. Lower prices on X3 CNC kits at CNCFusion.com
    By wisp in forum News Announcements
    Last Post: 08-10-2006, 05:37 AM
  4. Pre-loaded ballnuts now an option at cncfusion.com
    Last Post: 07-22-2006, 04:58 AM
