586,850 active members*
2,115 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > 85 mori sl-2h and mastercam issues (new to this machine with this software and lost)
Results 1 to 4 of 4
    Mar 2015
    5
    This machine and the negative x has me lost. Im trying to do a radiused front end and not getting much done. The software post in a positive x which I have to change to negative, otherwise the machine is on the wrong side of the centerline. Using G03 it looks like it's trying to do an inverted radius which makes me wonder if I'm supposed to change the r value to a negative so r center is on the right side of the work. Any feedback would be greatly appreciated.
    Feb 2009
    6028
    Re: 85 mori sl-2h and mastercam issues (new to this machine with this software and lo
    Ya, switch that sucker over to positive X. Not terribly hard to do, and only very minimal re-wiring. Post the control type and ill post the tech bulletin.
    Mar 2015
    5
    Quote Originally Posted by underthetire View Post
    The controller is a fanuk 11t. Sorry it took so long. The place is my second job so I work weekends there.
    Aug 2011
    2517
    if you want to just fix the code, you need to reverse X and G02/G03 as well. Leave R as-is.
    so if you have G02 X100.0 Z-5.0 R5.0
    it needs to be changed to G03 X-100.0 Z-5.0 R5.0
    if you are using I/K for arc center, reverse the sign of I only.
    In Mastercam the POST is pretty easy to change. You can just fix that and the code will be good to go as-is.
  1. Replies: 6
    Last Post: 03-30-2015, 06:14 PM
  2. Mori TV30 Drill/Tap XYZ Zero Location Lost
    By JerryH in forum Mori Seiki Mills
    Last Post: 10-09-2014, 04:05 PM
  3. looking for lost parameters for mori-seiki
    By landcfab in forum Machinery Manuals / Brochures
    Last Post: 06-18-2012, 05:23 PM
  4. Mori SL3 H Fanuc 10T F lost parameters and now almost runs well
    By rolandkra in forum Mori Seiki lathes
    Last Post: 07-11-2011, 09:01 AM
  5. Mori NV5000 lost X,Y,Z,W zero reference
    By teal854t in forum Uncategorised MetalWorking Machines
    Last Post: 08-25-2007, 02:34 PM
