587,218 active members*
2,775 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc O-TT will only run program with rapid in setup mode
    Apr 2007
    11
    I'd first like to thank Memeoryman for trying to find a way to get my one lathe to accept parameters as written in my first post.
    Ok, I got another one of my 3 Wasino SS-8 lathes working but for some reason it will only run a program if the rapid is set in setup mode. As soon as I change it during the program, the program stops and when I switch back setup, i can press start and the program will continue. It won't work at the start of a program either unless it's in setup.
    Also, I keep getting 434 and 444 axis detect alarm or something like that, (3rd and 4th axis for the robot loader). As soon as I unplug the 2 cables on the servo amp and plug them back in the alarm goes away
    Any suggestions to fix these problems would be great. Thanks,
    Kevin
    Apr 2009
    1379
    Sorry, Kevin. Should have given you my home number. Still no call about the option param problem Will try again Monday. I should be able to come Tuesday.
    Bill
    Apr 2007
    11
    Quote Originally Posted by memoryman View Post
    Bill
    No need to apologize, that was an honest thanks for the effort you've put in to trying to solve one of my many machine problems lol. I'll talk to you on Monday. Time for me to take a holiday tomorrow and check out the Indy in Toronto.
    Dear Memoryman
    I need the procedure to enter the Parameter in Fanuc oTT system
    L. Sakthivel
    Email:[email protected], website:www.premierengrs.com
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 01-20-2024, 10:34 AM
  2. Override rapid feed rate in program?
    By donl517 in forum Fadal
    Last Post: 09-18-2009, 06:36 PM
  3. no part program apears in dnc mode
    By YOO in forum Fanuc
    Last Post: 04-14-2009, 02:12 PM
  4. Rapid height? Basic router setup help
    By Ranscon in forum WoodWorking Topics
    Last Post: 10-15-2008, 01:29 AM
  5. fanuc 21-I no 100% rapid
    By bman356 in forum Fanuc
    Last Post: 09-29-2008, 01:23 PM
