587,089 active members*
3,008 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > tool engagement angle
    Jun 2017
    8
    How do you use tool engagement angle in fusion 360 cam
    I have searched online but do not figure out how to use it, nor find the code for tool engagement angle
    Feb 2009
    311
    Re: tool engagement angle
    Quote Originally Posted by perinj95 View Post
    In Autodesk CAM there is no parameter for "tool engagement angle" specifically. Instead the adaptive tool paths use the "step over" value, which is then converted internally to an engagement angle. The engagement angle can be calculated from the step over with some math.
    HSM Machining > Calculating Tool Engagement Angle, Radial Depth of Cut
    C|
    Jun 2017
    8
    Is there a app for android that calculates it ?
    Feb 2009
    311
    Good question. There are lots of machinist calculators but I don't know if any of them calculate engagement angle. I know GWizard and HSMAdvisor for PC do.
    C|
    Oct 2010
    171
    depth of cut = r - (cos{engagement angle} x r)
    in language: The depth of cut is the radius of your cutter MINUS (the cosine of your desired engagement angle times the radius of your cutter)
    e.g. what is the depth of cut for 45° engagement angle on a .500" end mill?
    .25 - (cos 45° x .25) = .073"
    Of course it's in the corners where things get more interesting!
    PM
  1. Two Angle Tool to Mill Out Inside Cylinder
    By saschad in forum SprutCAM
    Last Post: 10-24-2015, 04:01 AM
  2. DRILLING WITH RIGHT ANGLE HEAD TOOL
    By fsa in forum PTC Pro/Manufacture
    Last Post: 03-19-2013, 03:46 PM
  3. A2100 Tool Manager - Display Tip Angle??
    By laka in forum Cincinnati CNC
    Last Post: 12-19-2012, 07:48 AM
  4. 3D Contouring Tool Engagement Settings?
    By hodge_thomas in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-08-2010, 10:22 PM
  5. angle iron & flat bar comb tool
    By anil in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 09-29-2007, 07:13 AM
