Feed-Forward setting
In Version 2.6 firmware, i've added a Feed-forward setting. This reduces following error when running at speed.
With a step servo drive, it is 'pulled' along by the step pulses, its like a stubborn mule that doesn't like to be lead, the faster you go the longer the rope is stretched. The feed-forward is like someone running behind with a pitch fork.
Hows that for a technical explanation
Manufacturer of CNC routers and Viper Servo Drives
www.LarkenCNC.com and www.Viperservo.com
