587,511 active members*
3,336 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire and Gravograph IS6000 + Replace spindle motor
    Jan 2016
    I'm Paulo Santos from Portugal, and i need some help.
    How can i replace the spindle motor from my Gravograph IS6000 whith out call the gravograph services.
    I have a 75 W spindle motor and i want to replace for one more powerfull.
    Another question: The Software ASPIRE will full function whith the Gravograph IS6000 ?
    My IS6000 is from the year 2001 and the present software is Gravostyle 98, and is plugged in the parallel port on PC.
    Best regards,
    Paulo Santos
    Re: Aspire and Gravograph IS6000 + Replace spindle motor
    ASpire comes with a post processor for an IS6000. I would contact Vectric and ask them before purchasing.
    Sep 2005
    171
    The Aspire won't work on your machine. It is a propriatary type of software/hardware.
    I have an older New Hermes machine that I use aspire on, but had to convert it to run on Mach3.
    This involves rewiring, controls.
    I also used a rc plane style motor for the spindle drive.
    very complex project.
    Jan 2007
    1795
    that has a top loading spindle.. if you feel you ca get use a regular spindle then you can buy many type..
    heres one.. it has rpm up to 60000 and you can achieve a lot faster federate..
    0 3KW 300W 60000rpm Water Cooled CNC Spindle Motor with 1 5KW VFD Bracket Pump | eBay
    of course it pending on how much you plan to invest..
    changing the control... unless the old is real bad try to keep it..
    other wise that also will cost about 500.. true the machine you have has a great mechanic..
  1. Gravograph m20 Aspire Post Processor
    By arulnathan in forum Engraving Machines
    Last Post: 05-17-2014, 09:51 AM
  2. Brother TC731 spindle motor and driver replace Help
    By andrade in forum Uncategorised MetalWorking Machines
    Last Post: 05-09-2013, 06:15 AM
  3. Old VF-1. Need to replace spindle
    By JohnF in forum Haas Mills
    Last Post: 03-25-2013, 08:04 PM
  4. Replace spindle or?
    By gorby in forum Haas Mills
    Last Post: 12-19-2009, 03:52 AM
  5. Anybody here replace their X3's motor?
    By phantomcow2 in forum Benchtop Machines
    Last Post: 11-27-2006, 12:28 PM
