587,636 active members*
4,193 visitors online*
Thread: Load Monitor
    Nov 2006
    174
    Load Monitor
    I'm trying to use the load monitor on our Multus B400W, P200 control.
    Is there anything to show the load monitor is active?
    On our MA600HB Horizontal, when the spindle load monitor is used, a box is highlighted to say which monitor table/values are active when the load monitor soft key is pressed.
    In the program I activated the load monitor with...
    VLMON[1]=8
    I set the load levels on screen page 8 for the spindle. But when the program is running and press the LOAD MONI soft key, on the position screen, there is no sign of any active monitor.
    Apr 2009
    1262
    VLMON[1]=8 means that you are monitoring axis 8 (spindle) and doing it on part 1 (out of 64). You will want to look on the first part (page) and press the LIMIT LEVELS to adjust for your monitored axis.
    The page keys allow you to switch Axis when "trace" is active and switches part# when LIMIT LEVELS is active.
    ON the front panel there is a LOAD MONITOR key. When you press that, you will see MONITOR and AUTO SET soft keys. They will highlite Green when ON.
    Best regards,
    PS> we've posted on this before, so you may want to do a search to get more details on Load Monitoring.
    Nov 2006
    174
    Search first
    Ahh, thanks for the nudge to do a search first. I dived straight in with a question before thinking about it, didn't I.
    I've found lots of info to be going on with. Looks like it's different to the horizontal.
    Cheers
  1. LCD Monitor
    By Dyad1 in forum Fadal
    Last Post: 06-25-2022, 07:20 AM
  2. Spindle load monitor on Makino MC-100
    By swarfy in forum Uncategorised MetalWorking Machines
    Last Post: 03-07-2010, 08:54 AM
  3. Hurco VM1 Spindle Load Monitor
    By MidFloridaTech in forum HURCO
    Last Post: 11-22-2007, 07:15 PM
  4. monitor
    By rusticr6 in forum Haas Lathes
    Last Post: 10-25-2007, 01:06 AM
