587,404 active members*
3,260 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Series 2 cnc 2 hp motor on a series 1 bridgeport?
    Mar 2005
    271
    Does anyone know if a bridgeport series 2 cnc 2 hp motor will fit a series 1 variable speed bridgeport mill.
    Thanks Mike
    Feb 2007
    198
    The shaft diameter is different on the 2hp motors than on the 1-1/2 motors. I think the varidisk setup is slightly different also. I would avoid getting the motor with hopes of replacing a non-cnc machine motor.
  1. Bridgeport CNC Series 1 vs Series 2
    By jshank in forum Bridgeport / Hardinge Mills
    Last Post: 06-27-2012, 11:54 PM
  2. bridgeport series 0ne
    By valmet58 in forum Bridgeport / Hardinge Mills
    Last Post: 02-11-2008, 10:06 PM
  3. Replies: 0
    Last Post: 08-06-2007, 04:00 AM
  4. Identifying Bridgeport Series 2 Interact 4 Spindle Motor
    By UKRobotics in forum Bridgeport / Hardinge Mills
    Last Post: 05-26-2006, 12:55 PM
  5. Bridgeport series 1 or 2 ??
    By drill in forum Bridgeport / Hardinge Mills
    Last Post: 11-28-2005, 03:17 AM
