587,698 active members*
3,725 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Question Abouth LMS' "Solid Column Conversion Kit"
    Sep 2008
    107
    Hello,
    I just received from LMS the solid column conversion kit, #4483, and the recommended (Chris' tips) Y axis feed screw, #3944.
    When I went to install them into my Micromark #84630 mini mill, I was surprised to find out that the new Y axis feed screw I just got from LMS is the same length as my original Y axis feed screw. Apparently it's the exact same part.
    Being that the ways on the new base are about 2" longer than on the original, I thought I was buying a new feed screw that would allow more Y axis travel, accordingly. (Actually I do have a little more Y travel now simply because the "obstruction" is gone, but now the travel is limited by the length of the feed screw).
    I'm wondering, did anyone else buy the kit - and a new Y axis feed screw - and have the same problem?
    I'm wondering if I just received the wrong part, or if LMS is simply mistaken about the need for this part, or what exactly is going on here.
    Nelson
    Sep 2008
    107
    I emailed LMS, and they replied that they're going to send me another one. Apparently their stock had some standard length screws mixed in with the longer ones.
  1. Does the LMS solid column conversion kit make a big difference?
    By Nelson_2008 in forum Benchtop Machines
    Last Post: 10-02-2014, 10:10 PM
  2. K6100 conversion to LinuxCNC "Build" thread.
    By kiwichris in forum LinuxCNC (formerly EMC2)
    Last Post: 11-26-2012, 12:23 PM
  3. Replies: 25
    Last Post: 05-05-2011, 10:46 PM
