587,125 active members*
3,455 visitors online*
Results 1 to 20 of 29
    Jan 2008
    13
    Fanuc 400 alarms and other
    I am having a boat load of problems with my fsg-2460 grinder. I keep getting 400 alarms and such. Also, my table often stops halfway to dressing. I have to push the table the rest of the way. When it doesnt stop, it slams so hard into the dress posistion, that it trips more alarms !!! Any thoughts ? I have manuals, but after spending much time reading ( between running the other grinders ) I am having no such luck.
    Feb 2007
    464
    400 alarms are servo related.
    Something is stuck.
    Stefan Vendin
    Jan 2008
    13
    Like what ?
    Feb 2007
    464
    Quote Originally Posted by alphatad View Post
    Like what ?
    Remove top of the table and take a look under it.
    I guess it could be a faulty servo motor as well.
    Stefan Vendin
    Jan 2008
    13
    Did you notice it was a 24x60" surface grinder ? ? ? ? ?
    Taking the table off is easier said than done..
    Feb 2007
    464
    Nope,I missed that.
    Forget the table unless you have a forklift.
    Something is sluggish so try to remove some covers and take a look.
    A lead screw is probably moving the table.See if it's dry.
    Stefan Vendin
    Jan 2008
    13
    Quote Originally Posted by Mitsui Seiki View Post
    Nope,I missed that.
    I have the forklift, and have removed table before, just not very much fun. The table is hydraulic.
    Feb 2007
    464
    Disconnect the hydraulic hoses and move the table.
    If it's easy to move then it's the hydraulic system.
    Stefan Vendin
    Jan 2008
    13
    Right now, i can move the table by hand with everything hooked up normally.
    Feb 2007
    464
    Maybe it's a hydraulic valve?
    Stefan Vendin
    Jan 2008
    13
    See, that's what i was thinking.....
    Jan 2008
    13
    I removed all electrical connections from the hydo box to the grinder. Still problems. I think i might try the hoses.
    Feb 2007
    464
    Yes, and it can be the pump.
    Stefan Vendin
    Jan 2008
    13
    What does the prop amplifier do ? i know it has do do with the hydro table. When we were having stopping problems, a little bit of adjusting on it helped.
    Feb 2007
    464
    I'm not sure.I think it controls the valves.
    Stefan Vendin
    Feb 2007
    464
    Have you checked to see how much pressure the pump delivers.
    Stefan Vendin
    Jan 2008
    13
    The pump is good. Lots of pressure according to the guage.
    Feb 2007
    464
    Pump's good,table's good. It has to be one of the valves.A check valve maybe?
    Stefan Vendin
    Jan 2008
    13
    I figured it was the directional control solinoid, so i removed it, and everything else that controls the tables movement. I am going to have it checked out. I turned the grinder back on, and still the alarm....
    Feb 2007
    464
    Ok,post back when you have had the solinoid checked out.
    It'll be interesting to know what caused the alarms.
    Stefan Vendin
  1. Fanuc 0t-C 409, 414, 424 alarms
    By acerocket in forum Fanuc
    Last Post: 12-08-2015, 06:56 AM
  2. Fanuc 21-tb alarms
    By Hlynur in forum Fanuc
    Last Post: 12-06-2012, 04:44 AM
  3. Fanuc 0TC with 409 AL-31 alarms
    By bob1112 in forum Fanuc
    Last Post: 07-07-2007, 12:04 AM
  4. Fanuc OT alarms
    By cncmike92 in forum Daewoo/Doosan
    Last Post: 04-23-2007, 01:57 PM
  5. Fanuc 6MB 401 and 410 alarms
    By john braks in forum Fanuc
    Last Post: 02-24-2006, 07:45 AM
