587,887 active members*
3,346 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Using tool diameter for cutter comp
    Feb 2014
    Hi, and thanks in advance for any help. Is there a setting in Surfcam Velocity 3 that allows the use of tool diameter (rather than radius) for cutter compensation? It was never an issue when I was running my own shop, since all of our machines (Fadals) were set up to use tool radius. Now I work at a "Mastercam" shop that keeps their machines (also Fadals) set up to use cutter diameter rather than radius. I know how to change it at the machine control, but my employers don't want to take a chance on me forgetting to set it back when I'm finished (wouldn't happen, but hey...their tools, their rules). I personally despise working in Mastercam; for me its kind of like trying to program in Mandarin Chinese...although I can do it if absolutely necessary. The shop allows me to use my seat of Surfcam to write my toolpaths, but having to repost with a different tool definition every time I need to compensate for wear is a royal pain.
    Please forgive me if the answer to my question is one of those "right there on page #2 of the manual" things, I'm gettin old.
    Apr 2003
    637
    "Stock To Leave" you can input a negative number. Not sure where else you can compensate in the program. I've found over the years that most carbide tooling runs .0005 to .001 undersize so we use -.0005 on the stock to leave on most everything 2D. If the tool is not cutting to program size we just replace the tool.
    Nov 2013
    26
    I'm confused , Surfcam only can turn on or off cutter compensation G41, G42 , or cancel G40 when writing code.
    Then its controlled by the Machine tool control for offset.
    I see your changing the machine parameter from Dia to radius, there no software that can change machine parameters in its code.
  1. Replies: 2
    Last Post: 02-11-2014, 01:17 PM
  2. Replies: 5
    Last Post: 12-16-2013, 12:58 AM
  3. Help Needed: Lathe live tool milling Cutter comp.
    By joseph10s in forum Hyundai Kia
    Last Post: 03-30-2011, 03:08 AM
  4. Cutter comp on an id hole< cutter diam.??
    By PaintItBlue in forum Haas Mills
    Last Post: 05-06-2008, 12:30 AM
  5. Can I adjust cutter comp diameter within a program?
    By davereagan in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-20-2007, 05:12 PM
