I have a Hardinge HC lathe that the Lord gave me which was converted to CNC by Hasbach. Mechanically, it is in great shape, but unusable due to the rest of the controller being on the fritz. It has a Bandit control which drives the X,Z stepper drivers. When I turn the unit on, the steppers get rock solid which means the output drivers are working fine (they can support 7.5 amps so why not use them).
I would like to get a breakout board and use a PC to drive these steppers using Mach3. I have the schematic for the board, and I am not sure how to control all those inputs (they come in on a 16 pin ribbon cable).
Here is a list
1 PHB1 These three connect (eventually) to B1, B2 outputs to stepper
motor
2 PHB2
14 PHBC
3 PHA1 These three connect (eventually) to A1, A2 outputs to stepper
motor
4 PHA2
15 PHAC
5 12 V on motor logic (says +E in that schematic), but does not seem to
be connected to driver card that I can see, but may have been left off.
6 REV Inside motor logic is connected to 16 across a diode in /
transistor out - looks like Opto-isolator, but inside motor driver it is connected thru resister to TB1 Rev Lim
7 FWD Inside motor logic is connected to 16 across a diode in /
transistor out - looks like Opto-isolator, but inside motor driver it is connected thru resister to TB1 Fwd Lim
16 LIMCOM goes to +E
8 GND
9 ENAL 9 & 10 are connected thru diodes to +E and motor current pot
and lots of other circuitry including the AA (COM) & BB (COM)
10 ENAH
11 GND-X From motor logic, but driver schematic does not show
connections to driver card
12 NC
13 NC
I was an electronic tech in the Navy, so I can read the schematics and I can wire up something just need some help.
If there is anyone that has used these drivers with success, please let me know.
Thanks - Astroboy
