587,210 active members*
3,023 visitors online*
Thread: Bijur oiler
    Sep 2011
    38
    Bijur oiler
    i have a d2990 Bijur oiler to hook up
    what is the voltage 110/220
    or how to wire it up
    the tag is missing on the small motor
    the float guage is working
    i see 2 wires for float switch
    3 wires to motor
    blue red white
    any thoughts?
    harry
    Jan 2011
    29
    I don't have one quite the same as yours but it seems familiar
    On my BP Interact the two wires for the float go into your control system and on mine it didn't matter which two went where because it was just a switch
    The power can run off 110 OR 220 and it was White, Black and Red on mine
    The red was for the 220 and I cut it back and just used the (White and Black) for the 110
    Hope that helps
    "Anything that can go wrong, will go wrong". {To Hell With Murphy FIX IT!}
    Sep 2011
    38
    Thanks for the input
    the wire color code is red white and blue
    i would guess white for neutral
    red for 220
    am not sure , blue may be 110
    i just hate the smell of dollars burning up
    I found Bijurs web sight and have an email in to them
    again
    thanks
    harry
    Sep 2011
    38
    i just rec. email from Bijur
    20+ year old pump
    blue/white, insulate red for 110V
    blue /red, insulate white for 220V
    not trying to answer my own post but someone else might need to know this
    harry
  1. Automatic Oiler vs Manual Oiler
    By bruce34rr in forum Tormach Personal CNC Mill
    Last Post: 05-19-2010, 04:21 AM
  2. Bijur Pump - Wiring?
    By Scott Kelley in forum Uncategorised MetalWorking Machines
    Last Post: 09-22-2008, 07:37 AM
  3. Bijur oiler adjustment
    By sharp-shooter in forum Bridgeport / Hardinge Mills
    Last Post: 08-30-2008, 04:34 AM
  4. BIJUR OILER
    By tpmx57 in forum Bridgeport / Hardinge Mills
    Last Post: 06-08-2008, 10:33 AM
  5. Bijur Fittings
    By arsenix in forum Bridgeport / Hardinge Mills
    Last Post: 10-13-2005, 01:36 AM
