587,281 active members*
3,271 visitors online*
Results 1 to 8 of 8
    Dec 2007
    5
    i need cnc routing-milling machine
    i need a little cnc machine for fast prototyping pcb that contains TQFP 64 pin ic packages. can i achieve this resolution-precision with using gecko 203 drivers for 3 axis, 1.8 degree stepper, and proxxon mf70 ?
    is there any good , low cost alternative? http://www.k2cnc.com/shop/proddetail...%2D2514&cat=26
    what is your opinion about this product? has it anought precision?
    Dec 2006
    532
    if you need something small, consider one of these: http://cgi.ebay.com/WidgitMasters-Pr...QQcmdZViewItem
    a very nice machine that member Widgetmaster makes.
    Dec 2007
    5
    Quote Originally Posted by rustamd View Post
    how can i trust that specifications? and which one is more suitable because prices of them are close and k2cnc gives steppers.http://www.k2cnc.com/shop/proddetail...%2D2514&cat=26
    is gecko 203 right choice?
    what is the most little milling-cutter pen? is 0.01 mm possible?
    Feb 2007
    4553
    To a get a system that will hold .01mm you are going to spend alot more than any of the machines you are looking at
    Dec 2007
    5
    Quote Originally Posted by jalessi View Post
    for example? how much money will be enought? and is there any example around , i wantto see it.
    and how many mm can i hold with these (k2cnc machine) machines?
    Feb 2007
    4553
    Holycnc,
    The machines you mentioned might hold .025mm, I would look at a Minitech if you are serious about holding .01mm or better.
    http://tinyurl.com/28dtub
    Also you might want to look at a NSK Astro Spindle Motor because the runout might be a problem otherwise.
    Plan on spending about $12,500.00
    Take care,
    Jeff...
    See attached link
    http://www.minitech.com/itemdesc.php?ic=3
    Jan 2008
    10
    www.accuratecnc.com
    I have A360 (USB2.0) with camera (~9000$) - really good machine !
    Jan 2008
    10
    Example (produced with A360):
    - TSSOP 38 pins with 8 mils pads and 7.5 mils insulation + full
    copper rubout. Manufacturer states 4 mil traces, 4 mil insulation are OK.
    - screen shot from the software
  1. pacer routing/milling machine
    By woodman-46 in forum CNC Machining Centers
    Last Post: 03-06-2020, 08:30 PM
  2. New To Cnc Routing And Milling
    By mike robson in forum European Club House
    Last Post: 03-26-2007, 09:50 AM
  3. Large Planing/Milling/Routing Table
    By UrbanLogger in forum DIY CNC Router Table Machines
    Last Post: 01-11-2006, 10:29 PM
