587,218 active members*
2,806 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Tormach TTS holders
    111
    Tormach TTS holders
    Has anyone been successful at adding named tool holders to there tool table. Eric at SprutCAM America sent me the numbers needed to make the holders but I keep getting an error when I try and save the table.
    Dave
    Re: Tormach TTS holders
    Dave, You did not say what version and release of SprutCAM you are using.
    This is how I add new adapters/holders in Sprutcam 8
    Attachment 251466
    Go to Tools Library and select "Adapters"
    Then go to "Names" Dropdown
    Attachment 251444
    Select "Add new record"
    Attachment 251446
    "New" should be added
    Attachment 251452
    "New" should be in the drop down menu
    Attachment 251454
    Rename "New" to the name you want, TTS Test in this example
    Attachment 251456
    Now "Post edit"
    Attachment 251464
    Now "Save library"
    Attachment 251458
    Go to Parameters, Holder name Dropdown and "TTS Test" should be in the drop down list
    Select "TTS Test"
    Attachment 251460
    Now your holder should be "TTS Test"
    Attachment 251462
    David
    111
    David
    That did the trick. Thanks a lot.
    Dave
    Glad it worked Dave
    Maybe you could post the TTS Adapter/Holder numbers in a new Thread
    David
    Nov 2007
    2151
    Good job David.
    Looks like your developing a note book like me!
    Nice to have someone else posting some how to do screens.
    A person can look real fast make notes and apply.
    I notice under feed rate in your tools library you have some default of 0.1
    I found any value less then 1 that makes it to g-code and then loaded and run on my 1100 mill will make mill go to z limit switch.
    And you will be back at sprut fixing it
    md
    md
    Sharp Eye!!
    I upgraded the 2005 Tecra Laptop Pentium M 2Ghz to SC 8 Build 2, Rev 75464 dated 19/09/2014.
    The screen shots are from the Tecra default SC8 install.
    So you are seeing the default feed rate of 0.1 in the tool tables
    David
  1. Tormach 1100 S3 using Tormach 1.5" face mill....
    By dneisler in forum Tormach Personal CNC Mill
    Last Post: 05-06-2015, 04:50 AM
  2. Is there interest in Tormach TTS Holders?
    By abeship in forum For Sale Only
    Last Post: 06-08-2014, 12:53 AM
  3. Chinese ER32 Tormach Compatible Tool Holders
    By jttoner in forum Tormach Personal CNC Mill
    Last Post: 03-08-2013, 05:49 PM
  4. Anyone ever made their own tormach style holders.....
    By pete from TN in forum Benchtop Machines
    Last Post: 12-25-2011, 07:58 AM
  5. Current Tormach TTS tool holders ATC compatible
    By cheetahcnc in forum Tormach Personal CNC Mill
    Last Post: 12-13-2011, 09:19 AM
