Dear all,
My lab recently bought a PCNC 1100 series 3 with a deluxe stand. I was working on assembling them and I found that the perpendicularity of the spindle to the table surface is off by about 0.13/200 in x axis. While this is much more than the tolerance in the certificate of inspection(0.04/200), I called Tormach and they said this may be caused by not putting shims between stand and mill since "the stand and mill are not designed as a matched pair". Has any of you who also bought PCNC 1100 encountered this problem? Or fix it by inserting shims between stand and mill?
Thanks a lot.
Chennan
