587,597 active members*
4,138 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G0704, Too tight Column Bolts
Results 1 to 7 of 7
    May 2014
    8
    Received my G0704 yesterday and I am trying to move into the building by disassembling into 3 parts
    Jan 2014
    70
    Re: G0704, Too tight Column Bolts
    I removed table and head and was able to move the column/base myself and lift it onto the stand. As a noobie I didn't want my first operation with the mill to be tramming the column.
    I don't have anything helpful to offer about the column bolts, just thought I'd throw that out there. Congrats on the new mill!
    Sep 2012
    323
    These Bolts have lock washers on them. I want to say I had to put an "extension" bar on my hex key to get them loose. But that was over a year ago for me at this point.
    Andrew
    Nov 2009
    4415
    I remember they were tight. I probably used a cheater bar of some kind.
    A lazy man does it twice.
    1943
    Those bolts need to be tight. You need to use a hex key socket like the ones pictured here instead of a standard L shaped hex key. You can use these with a breaker handle and get lots of torque. Attachment 236908
    Aug 2013
    194
    I was just about to say a pipe is a very cheap cheater bar. 109jb's suggestion with a torque wrench should be a good idea.
    here is a chart to give you a range to torque to.
    May 2005
    3920
    Quote Originally Posted by rrangana View Post
    I managed to loosen them using a long pipe handle. Ok… looks like these bolts indeed needs to be very tight. When I assemble the mill will tight these bolts really good.
    Is 90 foot pound is good?
    Depends upon the bolts. I'd look up common torque values for the size of bolts you have on the net. The nature of the application demands a heavy pre load on the bolts.
  1. WTB: Used Square Column Mill Washington / Oregon G0704, PM25MV, or PM30MV!
    By Contract_Pilot in forum Want To Buy...Need help!
    Last Post: 01-18-2014, 06:21 PM
  2. G0704 column bolts?
    By exitium in forum Benchtop Machines
    Last Post: 03-04-2013, 01:35 AM
  3. Column gibb is binding on g0704
    By Nada mucho in forum Benchtop Machines
    Last Post: 02-02-2012, 01:27 PM
  4. Need dimensions for housing bolts (not mounting bolts)
    By rcpilot82 in forum Stepper Motors / Drives
    Last Post: 09-22-2011, 02:29 AM
  5. HARBOR FREIGHT small round column mill to a square column conversion.
    By motomitch1 in forum Vertical Mill, Lathe Project Log
    Last Post: 12-01-2005, 05:24 PM
