I've been here for quite a while now, I don't know if I ever actually started a thread myself. Mostly just commented on others, or tried to answer questions. Time to change that! :wave: This is my "almost second" CNC build, the first was really a bunch of modifications to a Taig CNC mill I got from eBay years ago. I need more cutting area, and I sold the Taig to where I work, so this will be my first "scratch-built" machine for home. I'm using the same Thomson Superslide linear slides on this machine (though longer ones) as I've had on the Taig for several years. I mill mostly aluminum all day long with it now, sometimes steel (with many passes to get through the .5" stuff). These slides are great all-in-one units, no worries about alignment or linear bearing mounting; everything is already done. They'll do 400IPM easy, though I usually keep them around 200. (9" runs out real quick at 400..) The only down-side is that most of them aren't pre-loaded nuts so the current Franken-Taig has about .003-.004" backlash, which sometimes shows. The 15" Y axis on this one has preloaded double ball nuts, but I'm going to need to add some to the X and Z axis.
This drawing is nowhere near complete, but I just wanted to get it out there and see how bad the flames get. I don't even know what to call this thing, but since it most resembles a DIY-router, I figured this group was as good a place as any. I'll be routing plastic and carbon fiber sheet with it, as well as aluminum. It's a moving table, bridge-gantry type I guess? The whole gantry will move up and down on (2) 9" slides, which I figure will give me the most available Z space, along with being really solid. I only have 48" x 36" to fit it in (existing enclosure), so I'm basing some of it on that. The Y axis parts aren't shown, but the table will ride on 2 more linear bearings on either side of the slide that's shown. The table will likely be an arrangement of 1" thick 8020 with a 3/4" thick Mic6 plate on top, or something like that.
The Z axis uprights and the X gantry are 3060 (3" x 6") 8020 extrusions, with 5/8" aluminum plates bolted on to attach the slides to. The slides themselves have another 3/4" - 1" thick aluminum structure on them. The corner and back supports are 1/2" aluminum plates with a bunch of bolts and T-nuts. There will be another 8020 stick on top of the Z uprights to add rigidity too. Underneath the frame (where the Y slide mounts to) will probably be a sheet of 1/4", 3/8", or 1/2" aluminum, with another stack of 1" 8020 bolted to the bottom of it all for strength. (depends on the price of the AL sheet in that size...) I'd like to mount it all to a slab of granite, but no way I'm getting 400 pounds of granite into the spare bedroom!
The Taig spindle is shown just because that's what I had drawn before in SolidWorks. It will either: stay the same, with a DC motor; be replaced by a router with the variable drive from here on the Forum (neighbor noise issues might rule that out..); be replaced by a Chinese VFD / spindle; or if I get real stupid, be replaced by a Colombo or Perske spindle... (though I only have 120v..) Drive electronics are IM483 modules, with Mach3 and a breakout board going to a PC, same as I use now.
I have the slides, the 3060 aluminum, the 1530 aluminum for the base, and some other parts but need to finish the drawing before I order the 1/2" and 5/8" plate. No idea when I'll finish this thing, but I'd like to have it done soon. I'm tired of cutting 9" on the Taig, then moving over, cutting more, moving over.....
It's 1:30am so I figure I'll post up a pic and then get some sleep.
Comments? Improvements? Am I just nuts?
