587,560 active members*
3,512 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Wiedemann CENTRUM 2000Q - FANUC 6M Can't zero set.
Results 1 to 8 of 8
Hybrid View
    Question Wiedemann CENTRUM 2000Q - FANUC 6M Can't zero set.
    I have a Wiedemann CENTRUM 2000Q equipped with a FANUC 6m controller.
    It's a turret punching machine
    I stood still for a couple of years.
    Now when I power it up. I can move it on X and Y.
    When I push the ZERO SET BUTTON. It returns to it ZERO point, the turret resets to POSITION 21 and the autoindex return to "0".
    Normally the ZERO SET led should come on, but it doesn't.... (NO it's not broken) even if I wait for 5min.
    When I want to run my program. It says "ZERO NOT SET"
    I can repeat the zero set procedure, but nothing seems to happen.
    I check the "POS" It says:
    X1250
    Y1000
    T21
    C0
    Any ideas?
    Is the a parameter or setting I can check?
    i am confused about IT TOO, but till now no answers, maybe you can try to contact the suppliers from China , they may help you some tech supprt,
    i find a guy here China professional manufacturer of laser machine and cnc router. , hope can do help to you , good luck.
    Dec 2012
    9
    hi
    we have a c2000 most zero set problem on these machines can be put down to turret scissoring
    ie upper turret pulls slightly different way to bottom turret when index pin go in put machine in hand mode then push pin in button a few times watch the turret if it sissors then you must align the turrets because the parameter that tell index tool that the turret is set is pulled out of range when turret pins go in at zero set so it sits and waits some times you can push or pull on the top turret chain when index pins go in when zero setting if you hear a loud hiss of air and the index tool shafts spin you should get a zero set light
    Re: Wiedemann CENTRUM 2000Q - FANUC 6M Can't zero set.
    hi
    you have to chack parameter 73 need to be 350 and diagnostic 802 under 350
    Do you know how can i do zero set manaly I have alarm in my display but to take off alarm i need to go to MDI but without zero set I cant reach there
    Dec 2012
    9
    hi
    has it a 6m control or a o-p control
    you must enable parameter write enable to use mdi with out having a zero set
    to do this differs for each control on 6m turn on pwe switch inside control
    on o-p create emergencey state then press settings a couple of times to get to para write screen then enable para write
    Please can you explain me little bit more how can I do ?
    Sent from my GT-I9505 using Tapatalk
    Dec 2012
    9
    what control does it have 6m or op
    Nov 2006
    16
    Quote Originally Posted by bonesclarke View Post
    Dear All,
    Is any one having Post Processor for CENTRUM 2000/Q?
    CaH
  1. Replies: 7
    Last Post: 11-20-2019, 10:45 PM
  2. Replies: 4
    Last Post: 08-26-2018, 05:09 AM
  3. Replies: 2
    Last Post: 08-10-2018, 03:46 AM
  4. Replies: 0
    Last Post: 01-28-2014, 04:41 AM
  5. fanuc o p controled wiedemann
    By truyens in forum Fanuc
    Last Post: 07-29-2009, 05:30 AM
