587,238 active members*
4,048 visitors online*
Thread: TMC 1000
    Sep 2008
    TMC 1000
    Hi: I have a TMC 1000 CNC mill. One of the orizionals. There appears to be some slippage at times on the Y- axis. I may need to replace the lead screws, etc. Does anyone have any suggestions re: how to do this? where to get the parts, etc. Thank you!
    Tracey Point
    Nov 2006
    33
    I'm curious as to why you think the lead screw is slipping? Usually, unless you either did not lube it, or just plain wore it out, they work fine and last a long time. I would start at the connections to the lead screw, pulleys, motor clamps, whatever, and see if one of them is loose, first.
  1. Bridgeport VMC 1000
    By 417m in forum Open Source CNC Machine Designs
    Last Post: 01-07-2011, 07:12 PM
  2. Need to add a sub every 1000 lines or so.
    By Toymanf in forum G-Code Programing
    Last Post: 01-14-2008, 09:55 PM
  3. best cam under $1000
    By dougstrong33 in forum Uncategorised CAM Discussion
    Last Post: 07-18-2006, 09:18 AM
