587,760 active members*
2,833 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Need help with conquest 10-65
    Feb 2008
    16
    Running a program where I stop the spindle after first side is finished, flip the part and finish 2nd side. The problem is when the program hits M00, I can't restart the machine without resetting the program and then searching down to where I want to start the 2nd part of the program. Is there a parameter that I can change that will allow me to open the collet without resetting the program?
    Thanks in advance
    D
    May 2004
    4519
    There may be a parameter you can change, but for some reason I am thinking there is an M-code you can use to tell the machine to ignore chuck/collet open/close signal. Look in your manual for such a code.
  1. hardinge conquest 51
    By mikemck in forum Hardinge Lathes
    Last Post: 11-16-2015, 02:33 PM
  2. Conquest 250
    By wbp in forum CNC Machining Centers
    Last Post: 06-19-2013, 02:36 PM
  3. Hardinge conquest 42
    By gyroxis in forum Hardinge Lathes
    Last Post: 09-21-2010, 02:07 AM
  4. Conquest T-42 Hydraulic
    By imac in forum Hardinge Lathes
    Last Post: 04-27-2010, 09:04 PM
  5. Hardinge Conquest 42
    By newc in forum Hardinge Lathes
    Last Post: 02-25-2010, 01:10 PM
