587,787 active members*
3,027 visitors online*
    Oct 2010
    15
    Coolant Pump Causing Problems
    I am having problems with the coolant pump on our Mori MV50.
    If I pull the pump out of the reservoir it spins, quietly for as long as I leave it on.
    If I put it back into the reservoir it will spin for a few seconds before the relay starts smoking. I have cleared the lines up until the cylinder branches off to a lot of different lines. I have blown air from that point and it comes our the coolant lines.
    Any suggestions?
    Feb 2009
    6028
    Contactor starts smoking but the overload doesn't trip? Something fishy going on.
  1. FADAL 6080 COOLANT PUMP PROBLEMS
    By machinescnc in forum Fadal
    Last Post: 08-31-2011, 10:27 PM
  2. Milling die cast is causing me problems!
    By Micro Milling in forum MetalWork Discussion
    Last Post: 01-28-2010, 02:44 AM
  3. SOLVED - Backlash compensentation causing problems while moving 2 axes
    By Hirudin in forum Mach Software (ArtSoft software)
    Last Post: 03-01-2009, 06:03 AM
  4. E1 and G28 codes causing offset problems ?
    By northwestfab in forum Fadal
    Last Post: 10-02-2007, 04:03 PM
  5. current induction in control wires causing problems
    By Smertrios in forum Gecko Drives
    Last Post: 05-19-2006, 07:30 AM
