Hi Thread Viewer
The 1989 O mate M controller on a Bridgeport 412 milling center recently had a new board installed . Parameters were copied by hand and entered manually lacking a tape reader. One problem we found was that in the event of axis over travel, we have no way of clearing the error and as a result, the Handle mode is inoperative. Previous to the board change we cleared the error with the reset soft button and manually moved the axis in Handle mode. Now we have to slide the stop hitting the limit switch to clear the error and gain use of the Handle mode.
Any ideas if this is parameter related? We do not have a parameter manual.
Thanks in advance
