587,402 active members*
3,145 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > tnr compensation for circular interpolation on lath
Results 1 to 7 of 7
    Mar 2013
    I'm trying to machine tensile bars for a part we make and I can only use one tool to put a 3/16" radius on either end of the reduced section. I'd like to use a 55 degree diamond insert with a .008 tool nose radius. Is there a way to apply a tool nose radius compensation so it doesn't over cut when i try to circular interpolate this?
    thanks!
    1792
    Re: tnr compensation for circular interpolation on lath
    You just need to use the proper tool-tip number.
    The cutting point continuously changes so that the nose circle always remains tangent to the defined profile (circle, for example). This is done by the control automatically.
    Dec 2016
    10
    Quote Originally Posted by rothe22 View Post
    thanks!
    Hi there I thought if you put a G41/G42 in the program part of said tool it will cut to whatever radius you program?
    1792
    Quote Originally Posted by Timster View Post
    You guessed it correctly. OP is perhaps not using G41/42 at all!
    Mar 2013
    I haven't tried using G41/G42 yet, not sure how to use it and I wasn't sure if it would compensate for the tool radius to keep it tangent to the profile I'm trying to cut. I'm also not sure what to use for a tool tip number.
    2932
    IMHO, you really should take the time to learn to use G41/G42 for this, to eliminate manual calculation of the compensated values. If you decide to pursue this, it would help to know what control you are doing this on. TNR comp has rules that differ by control.
    As for which tool tip number you use, it depends on where you touch off the tool when setting the offset. On a Fanuc, Yasnac, or Haas, for example you could use 0, 3, 8, or 9. I would probably go with #8.
    Mar 2013
    I'm using a prolight 3000 turning center (pretty sure it's similar to a fanuc controller). Can some one show me an example of using g41/g42? I dont think I'm using it correctly.
  1. CIRCULAR INTERPOLATION QUESTION
    By colby2000 in forum Uncategorised MetalWorking Machines
    Last Post: 02-07-2013, 05:05 PM
  2. circular interpolation
    By pmesilver in forum Mach Mill
    Last Post: 04-10-2010, 01:20 PM
  3. Circular Interpolation
    By Deadwood in forum Mach Software (ArtSoft software)
    Last Post: 01-11-2009, 09:35 PM
  4. circular interpolation
    By sqatch in forum Dolphin CAD/CAM
    Last Post: 02-11-2008, 07:02 AM
