587,401 active members*
3,191 visitors online*
    Aug 2010
    45
    Lathe set-up reduction
    Good Morning,
    I am looking for a bullet point list of the best suggestion for reducing lathe set-up times. I have been programming and setting up lathes for many years and am now in a position that I need to help some other employees come up to speed and improve the overall training in the shop I am working in.(three months now) I just bought Mike Lynch's book on reducing set-up times on turning centers but have a meeting in the morning and wont be able to utilize it right away. Just bullet points are what I need unless you want to help out more extensively,
    such as.
    Tooling needed at each machine. (we have 8 lathes ranging from 19th century technology to a couple of years old)
    Suggestions of what can be done offline before tearing down the old set-up to be ready.
    Installed program for boring jaws if necessary for the next part. (parametric program that is customizable).
    All suggestions are appreciated.
    thanks
    tony
    Feb 2009
    6028
    Quick change tooling with an off line tool presetter
    New machines with large ATC's.
    SMW quick change chucks.
    Set up sheets with good descriptions and pictures
    Automatic RS232/or network to eliminate the walking back and forth from the computer.
    Aug 2010
    45
    Just looked up the quick change chucks on youtube. Awesome suggestion. looking into the quick change tooling. Coromat Capto seems to be the option I can find.
    thanks
    Feb 2009
    6028
    I always used to tell people, the quick change was just a bonus on those chucks. Jaws repeat awesome during changes, and, those things do not loose clamping force at rpm. great chucks for thin wall tubing since they require a lot less clamping pressures.
  1. Reduction drive for the X2
    By MrWild in forum Benchtop Machines
    Last Post: 03-11-2012, 01:31 AM
  2. Voltage reduction
    By ArlieD in forum CNC Machine Related Electronics
    Last Post: 08-27-2009, 04:31 PM
  3. Vibration reduction..
    By JerryFlyGuy in forum Mechanical Calculations/Engineering Design
    Last Post: 11-09-2008, 03:33 PM
  4. what gear reduction are you using?
    By stanglou in forum Waterjet General Topics
    Last Post: 01-07-2006, 12:21 AM
  5. 2:1 or 3:1 reduction...I'm not sure?
    By Bird_E in forum Uncategorised MetalWorking Machines
    Last Post: 08-18-2004, 02:32 PM
