587,215 active members*
3,226 visitors online*
IndustryArena Forum > CAD Software > Solidworks > VisualMill is now integrated and parametric with SolidWorks
Results 1 to 7 of 7
    Jan 2004
    3154
    www.integratedmechanical.ca
    Sep 2005
    1660
    Darebee, your using Visual are you not? Have you heard anything in regards to their 5 axis and how well it's working?
    Adding it into SolidWorks is a good move.. I've been doing pricing w/ SolidCAM recently but I'm glad I waited.. now I've got another option to test..
    My primary concern w/ 5 axis is that it is able to do the tool offsets in the program vs doing them in the Control software..
    Thanks for the heads up..
    J
    JerryFlyGuy
    The more I know... the more I realize I don't
    Jan 2004
    3154
    Double
    Jan 2004
    3154
    Hi Jerry
    I am sorry I know nothing about the 5 axis.
    I only use 4.
    FWIW I do not use cutter comp in my control. I run the code as generated and set stock values to +/- as needed.
    I think the 5 axis is a 3+2 system. I don't see why it couldn't be a 4+1 (but I don't make software so I don't understand programming intricacies)
    Jan 2004
    3154
    I should have added.
    Give Anita a call at MecSoft.
    They are very nice, will do online demos on your parts and you will get NO pushy sales calls (they better not make a liar out of me :stickpoke)
    They work directly with us users to resolve issues.
    Tell Anita Derek from Integrated Mechanical sent you and that she better treat you right.
    I believe there is a reseller in TO now, but I deal direct with MecSoft and have no intention of changing.
    Sep 2005
    1660
    Thanks Derek, I may just do that First I'll probably tag along on that roll-out on the 22nd. Then if things look good I'll get in touch w/ them.. I'm getting closer to doing a deal as I've had several projects of late that would have benefited greatly from multi axis [and less setups]..
    Thanks!
    J
    JerryFlyGuy
    Jan 2006
    4396
    Quote Originally Posted by DareBee View Post
    I can see your very happy about this!!!!
    Cheers!!!!:banana:
    Toby D.
    Schwarzwald
    www.refractotech.com
  1. Replies: 4
    Last Post: 09-15-2009, 09:21 PM
  2. Surfcam integrated into Solidworks.
    By John Welden in forum Surfcam
    Last Post: 05-20-2009, 12:11 PM
  3. Surfcam Integrated in Solidworks.
    By John Welden in forum SprutCAM
    Last Post: 05-19-2009, 08:15 PM
  4. Integrated CAM Advantages?
    By NexGenMfg in forum Uncategorised CAM Discussion
    Last Post: 07-19-2008, 03:28 PM
  5. Solidworks and Visualmill
    By debutpic in forum Visual Mill
    Last Post: 06-24-2005, 09:03 AM
