587,913 active members*
3,718 visitors online*
Results 1 to 10 of 10
    Aug 2014
    889
    Pattern maker.
    Any wood pattern makers in Canada? I need
    3 patterns made for grey iron castings. They are medium sized, the biggest piece measures at 20 wide x 50 long x 10 inches high.
    It's definitely a dying art here in this country.
    May 2008
    667
    Re: Pattern maker.
    Could you show us an example of what you need.
    Jeff
    Nov 2014
    37
    Re: Pattern maker.
    it is an art , I hate seeing casting shops going out of business and all the cool wooden patterns thrown away......
    I could use some patterns made too !
    Feb 2011
    423
    Re: Pattern maker.
    I am not in Canada but I am a jobbing pattern maker by trade. If I may be of any assistance please send me a private message.
    Aug 2014
    889
    Quote Originally Posted by slowlearner View Post
    I'm presently away from home. I'll provide
    a drawing via private message to interested parties just as soon as I get back.
    the first pattern will be the column of a VMM.vertical mwilling machine.
    it would need to be made of hardwood as production casting of 25 pc's is to start by mid June.
    I really can't afford screw ups, so experience in the processes of iron casting is paramount.
    The foundry here takes care of the flues and gates etc....
    They expect proper draft however and parting lines to be thought of beforehand as they shy away from poor patternmaking.
    196
    Re: Pattern maker.
    CMT-
    We are also a model and pattern making company that would be interested in looking at your project. However, like the other respondent above, we are not in Canada.
    We are in Akron, Ohio. Depending on where you are in Canada, it may not be that far.
    Thank you for your consideration.
    Doug Pryor
    David Wolfe Design, Inc.
    Akron, OH
    www.davidwolfedesign.com
    [email protected]
    Aug 2014
    889
    Re: Pattern maker.
    Jeff
    Attachment 265896
    As you can see, not that simple. Finite element analysis helps with beefing up the structure but is unfriendly to the mold and pattern makers.
    In any case, impossible to send private messages to dpryor or slowlearner, your inbox are full.
    Feb 2011
    423
    Re: Pattern maker.
    G59,
    Inbox has been cleared.
    Had no idea there was that much demand for a pattern maker.
    Aug 2014
    889
    G59,
    Can you email me, as I can't seem to figure out how to attach a file through private messaging.
    Can you work with a .stp file?
    If not, what file format works best for you?
    Jan 2007
    1795
    Re: Pattern maker.
    at Victoria bc I know one who could make it you...
  1. Pattern maker.
    By G59 in forum MetalWork Discussion
    Last Post: 01-21-2015, 04:48 AM
  2. Composites- Pattern and mold maker
    By ggreco in forum Employment Opportunity
    Last Post: 07-14-2012, 06:54 PM
  3. Looking for a die maker
    By Noxx in forum Diemaking / Diecutting
    Last Post: 06-16-2009, 05:50 PM
  4. Mold/pattern maker jobs,OHIO
    By coonhunter in forum Employment Opportunity
    Last Post: 09-25-2007, 08:41 PM
